Stock speakers, do you need an adapter for aftermarket?
Old May 11, 2003 | 04:25 PM
BlackMax2k1's Avatar
Do you have to drill new holes or is there an adapter you have to buy? I'm talking the 6.5" speakers in the front and back.
Old May 11, 2003 | 05:36 PM
Anybody ever use these?
Link
Old May 11, 2003 | 05:44 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
that looks like it will work...check out the audio forum...you should yield more answers...
I made my own brackets out of hardboard...
Old May 11, 2003 | 05:46 PM
Eat Naaawwwzzzzz
Actually it's dead over there so I posted here.
Old May 11, 2003 | 07:07 PM
gfys12's Avatar
those crutchfield brackets don't really fit too well. they will work but it is not a clean fit. i had clearance problems with those brackets. the window would bang against the speaker when slamming the door with window fully down. so i was just forced to use the half *** method. take your factory speaker and cut out the cone and magnet. use the rest of the original plastic ring as a new bracket. screw your new speaker to this. then screw the whole thing back in.
some body out there has a site with picts on this.
damn i should have taken some picts.
it works good. just takes a little time.
Old May 11, 2003 | 07:37 PM
So if I do this then I can't put the originals back in later?
Old May 11, 2003 | 08:01 PM
Guess not. I found a link to PhatGuy's write up. Too bad the pictures are so small I need a magnifying glass to see the speakers cut out!
Old May 11, 2003 | 08:09 PM
mclee45's Avatar
I use to work at circuit city and you do not need new brackets for your maxima. What we do is basically rip off those paper cone speakers and just cut off those plastic beams holding the magnet. make sure you cut off the whole beam. the new 6.5 in speakers should just fit on top of the bracket. just throw the paper cones and the magnet away unless ya planning on keeping it.
Old May 11, 2003 | 08:15 PM
Do you use the existing white plug on the edge of the bracket?
Old May 11, 2003 | 08:21 PM
mclee45's Avatar
no, we cut the white plug and just added female connectors to then. then just connect the connector to the speakers.
Old May 11, 2003 | 08:23 PM
mclee45's Avatar
you have to figure out which wires positive and which ones negative though. car shops usually juse have the books with color codes and what they are.
Old May 11, 2003 | 09:23 PM
WildmanAL's Avatar
I actually used the white plug. I just connected my new speaker wires to the clips. That's so if for some reason I need to remove them or put the factory (I'll have to buy new ones) speakers back in. I'll still have that clip to work with.
Old May 11, 2003 | 09:32 PM
I used the white plug too. The speaker holes don't seem to match up well with the original speaker bracket though. The holes are toward the edge. I'm using MB Quart speakers. Do they run bigger than other aftermarket speakers?
Old May 11, 2003 | 09:42 PM
WildmanAL's Avatar
When installing new speakers, you'll have to drill some new holes to screw the speakers down with. I have infinity kappa 6 1/2" all the way around.
Old May 11, 2003 | 09:46 PM
That's the thing I have nothing to drill into since the speaker mounting hole is farther outside than the bracket. I could do one side but that's about it. I'll figure something out.
Old May 12, 2003 | 06:09 AM
MaXBoost03_SE's Avatar
By any chance do you guys know what ohms the stock amplifier will handle decently? As far as whether to buy speakers that are either 4 ohms or 8 ohms.
Thanks in advance.
Old May 12, 2003 | 08:50 AM
mclee45's Avatar
buy 4 ohms
Old May 12, 2003 | 04:57 PM
SSandMaxima's Avatar
How do they sound? I was thinking of putting them in my Max... stock bass really sucks and I dont want to put in a subwoofer right now ...and was thinking about some Infinitys.
Old May 12, 2003 | 08:37 PM
cabernet's Avatar
If you have a Bose system you should have no problem with aftermarket speakers. If you don't (like my GXE) it can be a pain. I searched the entire forum to find the answer awhile back. I bought the Bose brackets for $8 each to simplify things. The other option as described above is to canabalize the exiting speakers to use the mounts on them. Another option, as mentioned also, is to make your own adapter using MDF (medium density fiberboard). I found it easier to pay the $8 - not the cheapest route, but the easiest. Or pay Bestbuy to install them at $40 per pair (worth it for me).
Old May 13, 2003 | 04:57 AM
code_slinger's Avatar
Here is how I usually figure out the polarity:
Use a 1.5 volt battery, and touch the speaker wires to the + and - poles of the battery.
Do this a few times and watch the cone move. When the + is corrected to the + terminal, the speaker cone will push forward as you touching the wires.
If you got it backwards, it will pull back.
Sure-fire method...
James92SE
142
Jan 2, 2024 09:23 AM
9aj9
Apr 5, 2020 12:11 AM
catalinvint
Sep 16, 2015 07:48 PM
popdedop
Sep 11, 2015 11:17 AM
A32goldylocks
Sep 2, 2015 06:39 AM
