Sunroof Woes
Old May 12, 2003 | 06:27 PM
WindFall's Avatar
Sunroof Woes
OK, last Friday Night my battery went dead with my sunroof open, and since i jumped it off and have driven it for a few days, the sunroof won't close. i tried disconnecting the batter for about 30 minutes but it didn't work. how can i fix it?
Wind
Old May 12, 2003 | 06:46 PM
Maximax2's Avatar
Re: Sunroof Woes
Wind
Sounds like maybe the switch is confused (if you miss the detents on the switch, the roof won't open or close - maybe it's misaligned). Try moving the switch all the way open, then all the way closed. If that doesn't work, maybe try closing it manually (with the switch all the way closed), then opening?
Old May 12, 2003 | 07:02 PM
WindFall's Avatar
you can close the sunroof manually?
Old May 12, 2003 | 07:09 PM
TimW's Avatar
The silent but deadly Moderator
why not do the reset procedure in the manual?
Old May 12, 2003 | 07:18 PM
saxdogg's Avatar
Old May 12, 2003 | 10:01 PM
Link9510's Avatar
What is the reset Procedure?
Old May 13, 2003 | 07:03 AM
griffy2k2max's Avatar
What you have to do is make sure that the sunroof is closed. then push the close side of the switch, you will feel a light click or you may even feel it in the switch, that will reset the sequence of the sunroof
Old Jun 23, 2003 | 03:13 PM
Papamonty's Avatar
Thanks for the sunroof reset procedures Griffy. I installed new Hella horns over the weekend and disconnected the battery. When I tried to operate the sunroof today it didn't open. Thanks again.
Old Jun 25, 2003 | 03:06 PM
No Problem
Old Jun 25, 2003 | 03:26 PM
GLE2000's Avatar
It won't move at all? Have you checked the fuse?
bigdogsteve
Jan 31, 2018 04:18 PM
Fbana41
Aug 29, 2016 12:18 PM
Forge277
Jun 13, 2016 09:26 PM
jonreidhead
Jan 6, 2016 09:38 AM
Vequity
Sep 10, 2015 05:26 AM
