will these fit my car?
Old May 27, 2003 | 06:02 PM
skandalouz's Avatar
Will These Fit On My Car???
there are these rims that i'm lookin at on ebay.. and it says that the bolt pattern is 5x114.....did he mean to say 5x114.3?... or is there such a size as 5x114? and the offset is 48.. can anyone tell me what the offset means?
eddie
Old May 27, 2003 | 06:05 PM
Dave Lopez's Avatar
Re: will these fit my car?
eddie
There is nothing shown from EBAY
Old May 27, 2003 | 06:08 PM
skandalouz's Avatar
i didn't put up a link... everything is stated in the question
Old May 27, 2003 | 06:37 PM
slickrick's Avatar
im not sure how a 48mm offset will look or if it will even fit.
Old May 27, 2003 | 06:41 PM
bsetiawan's Avatar
eddie
Courtesy of discount tire direct:
"The offset of a wheel is what locates the tire and wheel assembly in relation to the suspension. More specifically, it is the measured distance between the hub mounting surface and the center line of the rim. Below is an explanation of the various types of offsets which are pictured in the above graphic."
Old May 27, 2003 | 06:46 PM
skandalouz's Avatar
thanks for the explanation... but by the picture.. any positive offset would have no problem, fitment-wise, rite? or if the offset is too big, then will it push the wheel in too much?
Old May 27, 2003 | 08:17 PM
bsetiawan's Avatar
Too positive or too negative is not good. I think the range for Maxima is from +35 to +43 depending on the size of your wheel. Someone please correct me if I'm wrong. Basically don't make it too positive if your wheel is only like 7" wide, otherwise it will look weird.
Old May 28, 2003 | 08:47 AM
skandalouz's Avatar
well the wheel specs are 19x8.5... bolt pattern: 5x114.3.... offset: +48
Old May 28, 2003 | 08:49 AM
NT2SHBBY
the bolt pattern is good, the offset seems high...
Old May 28, 2003 | 08:57 AM
skandalouz's Avatar
hrm... ic... that was kinda what i was worried about...
Lakersallday24
Jun 16, 2019 01:35 AM
stromm
Aug 27, 2015 04:13 PM
carguy96
29
Aug 21, 2015 02:43 PM
twotonezed
Aug 16, 2015 11:41 AM
kirkhilles
Aug 8, 2015 10:53 AM
