Angeleye install on a 2001 gxe
Old Jun 11, 2003 | 10:34 AM
Ryanb126's Avatar
Since i have a 2001 gxe that comes without fogs stock, will i need to purchase a fog light switch if i wish to install the angeleyes?
Old Jun 11, 2003 | 12:33 PM
PCGuRu2K's Avatar
You can wire the Angel Eye fogs multiple ways. One way is straight to the foglight stalk. And the other you can just wire it to the switch that comes with the kit..
Old Jun 11, 2003 | 12:40 PM
oldmanmax's Avatar
Can you post pictures and how-to after you install the Angle eyes. I was thinking about doing it later on this year.
Old Jun 11, 2003 | 12:52 PM
PCGuRu2K's Avatar
The wiring is pretty much straight foward... For the angeleyes you tap into the daytime running lights. Just gotta run a relay. And for the h3 bulb you just tap that to the "+" coming from the harness on the foglights.
Old Jun 11, 2003 | 06:23 PM
00MAXIST's Avatar
How do you tap, can you put some of this laymens terms?
Old Jun 11, 2003 | 08:04 PM
95emeraldgxe's Avatar
you take the wire, strip it so that the conductor inside is exposed, then you strip a little bit of the + wire from the harness...then you connect the wires and cover it up with some electrical tape
Old Jun 12, 2003 | 04:21 AM
PCGuRu2K's Avatar
Yeap
Old Jun 12, 2003 | 09:46 PM
Ryanb126's Avatar
Do i need to take off any underbody pieces or can the fake air vents be removed from the outside?
9aj9
Apr 5, 2020 12:11 AM
markevans999
Oct 25, 2015 08:27 AM
rnb754
Sep 14, 2015 11:39 PM
GregL65
Sep 7, 2015 10:33 PM
mikebla
Sep 3, 2015 05:37 PM
