Looking into an UDP
Old Jun 13, 2003 | 09:47 PM
00MaxSE's Avatar
Pointy Elbows
Looking into an UDP
I'd like to get an UDP and after searching I've noticed that the people with the RVM pulleys have had problems with oil leaks.
I think I want to get the UR pulley. Has anyone had any problems with this pulley on their 2k-2k1 Maximas?
J.
Old Jun 13, 2003 | 10:10 PM
clipse's Avatar
From what I hear from other ORG. memeber's is that an aftermarket UDP is a worthless mod with minimal gains behind it.
Old Jun 13, 2003 | 10:52 PM
studman's Avatar
RVM's pulley is defective. Consider yourself warned about buying/installing/using one of their pulleys.
Other than that, there's not any problems (so far) with the UR or the Definitive pullies for the 5th gen, other than those who didn't change the oil seal, which isn't directly related to the UDP manufacturing/design itself, but more towards the age/milage of the engine when the UDP was installed. It is recommended that anytime you change the crankshaft pulley that you change the oil seal as well. You're already there, so you might as well go ahead and do it. You can get the seal from your local Nissan dealer for about $7.
You'll also need belts to go with the pulley. Be sure to inquire as to which size belts you'll need for your pulley and engine. The pulley manufacture should be able to tell you what you'll need, and you can find them at a local auto parts store.
Old Jun 14, 2003 | 07:27 PM
00MaxSE's Avatar
Pointy Elbows
Cool. Thanks
Old Jun 14, 2003 | 10:53 PM
Maximam's Avatar
And are there any real HP gains?
Old Jun 15, 2003 | 03:31 AM
Virus's Avatar
5-6hp If you do the install yourself it's worth it, if you don't, it's not. If you have extra cash to pay for the install, why not
Old Jun 15, 2003 | 03:44 AM
KLOOGY's Avatar
L33t BMW Drivah
Rates up there with RT cats on 5th gens ... POS mod....
Old Jun 15, 2003 | 09:22 AM
Maximam's Avatar
OK, so forget the UDP right now and get the 2k1 a Y-pipe right?
Dave B
May 29, 2001 11:07 AM
y2kse
Feb 25, 2001 08:47 PM
Andrew91SE
Nov 26, 2000 03:05 AM
ohboiya
Oct 9, 2000 12:23 PM
