Frankencar intakes
Frankencar intakes
Anyone break the strap that goes from the top of the drivers side strut mount to the intake itself? I was checking my oil today and i noticed that it snapped in 2 pieces!
The filter is still tight..I wonder if i email them if they would send me a replacement piece. Its made out of some cheap metal, no wonder the torque of the 3.5 broke it!
BTW, anyone check out there webpage? they modified it with some Flash stuff..pretty cool!
Re: Frankencar intakes
Re: Re: Frankencar intakes
Originally posted by Maximam
You need to isolate the intake from the motor. This is done on the stock box and should also be done on the Frankencar. Get an isolator from the midpipe to the throttlebody.
Re: Re: Re: Frankencar intakes
Im not sure what you mean?
Re: Re: Re: Re: Frankencar intakes
The flexible coupler that is connected to the stock box. Between the TB and the silencer. I believe the Altimas works well with the Frankencar. This will allow the motor to move freely and you won't have this problem. Also why not reduce vibration to the MAF. Mine is installed this way and works great. Look through the hood while in neutral and rev the motor, it rocks quite a bit. Under load even more. Nothing IMO should be fixed to the chassis from the motor
maxima297
Sep 30, 2015 03:32 PM
