Have UDP Installed or do it myself?
Old Jun 22, 2003 | 01:04 PM
bigdo26's Avatar
I've seen the posts for this before, saying it was hard to install the UDP on an auto. I have a buddy who works for Nissan, but doesnt have a lift at his house. Think we could do it in the driveway in a few hours? or is it worth it to just bring my car down to the shop? I have a 2k2 auto, as it says in the sig Also, i bought the belts required, do I need the... oil seal was it? from the nissan dealership? wanna make sure everything is gonna run fine and all....
Old Jun 22, 2003 | 05:29 PM
Fezzik's Avatar
Yeah you want to get a new oil seal when u put on a new crank pulley. They are not that much. But I am gonna do it myself cause I have air impact wrenches at home. It's gonna be tough to get the bolt off. After that. You should be fine.
Old Jun 22, 2003 | 06:23 PM
greekmax2k1's Avatar
i brought mine to a mechanic and he couldnt do it....i was so ****ed cause i left the car there for like 6 hours and he couldnt get that bolt off....i have to find someone to do it...if no try myself...i dont want to pay over 60 to install it....
Old Jun 22, 2003 | 07:13 PM
maximamaybe's Avatar
It is a biatch to install. I defineately recommend having an impact wrench. THe main problem is the bolts on the tensioners. They are almost impossible to get to. My hand was hurting for a week after.
Old Jun 22, 2003 | 10:01 PM
t56gen3's Avatar
Wussie! Quit ur whining! But I do appreciate the help!
Getting the stock pulley off the first time was actually pretty easy. Getting it out the second time, on the other hand, was a total b1tch. What worked for me was heating the bolt with a torch, then impacting it out. Appearantly there is some kind of factory loc-tite on that bolt.
I don't see any reason to replace the seal on a VQ35 unless it's leaking. And yes, you can do it with floor jack and jackstands.
Old Jun 22, 2003 | 10:37 PM
Fezzik's Avatar
I would go ahead and replace the oil seal even if it isnt leaking. That seal was formed for the other crank pulley. I would get a new one. I mean it's not that expansive. But that's just my .02 cents
Old Jun 23, 2003 | 07:02 AM
MaximaMan77's Avatar
You didn't say if your buddy was a tech or not. If he is and he can get some tools from work it should be no problem to do in the driveway. Ask him if he has an electric impact wrench, as it will make getting that bolt out and back in much easier. Also make sure you have some long extensions and a universal joint for the tensioners and all will be good.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
