press lightly on your hood... hear that?
Old Jun 24, 2003 | 09:50 PM
jay beede's Avatar
for some reason maximas seem to be set up with play in the hood latch. try this... press lightly on your hood near the front edge, just above the latch. can you hear/feel the hood move down slightly when you press? does it pop back up and make a "clack" noise when you let go? many gen5 maximas I have seen do this. the hood and latch must bang up and down against each other this way while you drive as well. I think the diameter of the ring attached to the hood is too small to be gripped tighly by the latch mechanism.
Leave it to Datsun to screw up a design that has been mature for 50 years!
Old Jun 24, 2003 | 09:53 PM
02'maxed-out's Avatar
it happens to me too... matter of fact... its all Maxima 2k and up, don't know about 2k4... Nissan...go figure... that is why we got some much hood vibration...
Old Jun 24, 2003 | 10:44 PM
UCF_94lude's Avatar
Re: press lightly on your hood... hear that?
yep, I noticed that when I waxed my car for the 1st time last week.
Old Jun 25, 2003 | 05:35 AM
2k2kev's Avatar
It's chrome alright...
adjust the bump stops and be done with it
Old Jun 25, 2003 | 05:37 AM
NT2SHBBY
it's the bump stops....good luck gettin them to line up perfectly tho..
Old Jun 25, 2003 | 06:18 AM
guapsnaman's Avatar
Is this why it's easy for those criminals to break into our cars and take our beautiful lights?
Old Jun 25, 2003 | 06:24 AM
2k2kev's Avatar
no, that's because of plastic tabs and a hood cable you can grab with your hand
Old Jun 25, 2003 | 06:25 AM
BiggD23
I have this too, I noticed it while washing the car. Doesn't the hood rattle TSB cover this? It rattles alot when I'm on the highway too.
Old Jun 25, 2003 | 06:43 AM
NT2SHBBY
the hood rattle covers a piece of weatherstripping attached to the underside of the hood..... it still rattles tho
Old Jun 25, 2003 | 12:05 PM
WHEELMAN_03_SE's Avatar
yeah mine does this **** too. i also noticed that my hood has about 1/8 of an inch gap between it and the drivers side light and about 1/2 an inch gap on the passenger side. dod some imbasul at the dealer spring it when they were prepping it for me to pick it up? can it be fixed or slightly re shaped like they do to small dents where they heat it up and fix it at a good body shop??
who knows
WHEELMAN
Old Jun 25, 2003 | 04:12 PM
trey
Yup i hear that also!
Old Jun 25, 2003 | 05:18 PM
2002 Maxima SE's Avatar
I tried raising the hood stops some, but it still rattles. Is there a way to lower the locking mechanism by like an inch or so?
Old Jun 25, 2003 | 06:21 PM
trey
I also adjusted my hood stops but it didn't get rid of my rattle, i brought it into the dealer and the rattle actually came from a broken braket in my front left headlight (which is were the noise was coming from). go figure.
Old Jun 25, 2003 | 08:00 PM
Nathan's Avatar
You can add my 2k2 to the list
Old Jun 25, 2003 | 08:15 PM
RC03MAX's Avatar
There are three bolts on the hood locking mechanism that allow for some minor adjustment.....I tried the hood stops too but it worked only on the ends of the hood and did nothing for the middle
Old Jun 25, 2003 | 10:26 PM
jay beede's Avatar
the problem seems to be the diameter of the "loop" spot welded to the hood. the slot in the latch is too large to capture and hold the loop tightly. rainig the rubber bumpers just makes the loop pull up somewhat against the latch... the play is still there. same issue with lowering the latch (which doesn't move too far). I tested this theory by putting a wrap of duct tape around the loop--voila, no more rattle. now I just need to devise a permanent way of increasing the diameter of the loop by about twice the thickness of garden variety duct tape.
Old Jun 25, 2003 | 10:35 PM
grey2002_ny's Avatar
The problem is that the latch has to be adjusted. I had the latch adjusted as part of the vibrating TSB and now the hood is real tight and doesn't budge when I push on it, or vibrate on the hiway
Old Jun 25, 2003 | 10:38 PM
jay beede's Avatar
it's good to hear that your hood issues have been remedied. ever have trouble with your power windows?
Old Jun 25, 2003 | 11:54 PM
96_vqmax's Avatar
I wouldn't try it with duct tape though,if it come off or melt then you prolly have problem opening your hood.Just my $.02.
mvm062
Nov 30, 2020 09:00 AM
boomerbrian
Oct 31, 2018 10:25 AM
Maxima30
Sep 7, 2015 06:13 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
dcardello
Sep 3, 2015 11:44 PM
