RSB problem!!!
Old Jul 2, 2003 | 07:02 PM
Maximam's Avatar
RSB problem!!!
Under compression the rear brake lines touch the RSB mounts. How is this avoided? I have moved the mounts front and back but the lines get crimped under compression. Design flaw?
Old Jul 2, 2003 | 07:38 PM
spta97's Avatar
This is what I did. I think I'll move the mounts back closer to the bend, but other than that it worked out. Ask questions if you don't get the jist from the pic.
*edit* This is the Cattman performance one
Old Jul 2, 2003 | 11:20 PM
Maximam's Avatar
Thanks for the help. I have my mounts about that far back now and it helps. I had two people jump up and down in the trunk to get full compression and it seemed ok. With the struts disconnected, the brake line interfered with the mount under compression. I am thinking that amount of compression was past the struts bumpstop.
BTW moving the mounts in more (about 2.25 inches) made a night and day difference. The car rotates much better now.
Old Jul 3, 2003 | 09:55 AM
Maximam's Avatar
Any other suggestions?
Old Jul 3, 2003 | 10:55 AM
Maximax2's Avatar
I haven't noticed any crimping under compression, but I did what spta did (I think) and moved the trailing arm brackets about 5" from the end. This way they're behind (to the rear of the car) the brake line bracket, and I could re-install. The only thing I'm a little concerned about is rubbing on the bolt - noticed yesterday that the bolt has sawed through the electrical tape I added. Don't know if this means a) need to monitor this forever and change tape when necessary, or b) electrical tape is a lot easier for the bolt to cut than the actual rubber coated brake line...
Old Jul 3, 2003 | 11:16 AM
Maximam's Avatar
Have you seen the design of the Stillen? A MUCH better design. I may switch. I should have just went with the Stillen instead of trying to save $$$.
See how the bar is flat at the ends? The mounts are very slim.
Old Jul 3, 2003 | 08:05 PM
spta97's Avatar
Did you move them toward the front or rear of the car? The reason I moved them there was because someone said it increased the effect of the RSB. To be honest, I think my FSTB made more of a difference. I think I'll try moving the mounts to the end where they are supposed to be.
Old Jul 3, 2003 | 08:46 PM
Maximam's Avatar
Actually I just moved the mounts toward the rear of the car and it made a night and day difference in the rotation of the car. The understeer just went by by. I have 2.5 inches of the bar showing in front of the bushings. The RSB made a BIG difference.
The FSTB did tighten up the steering very well but also increased understeer doing it. Now the RSB helped that problem.
IMO, doing just one without the other makes for an unbalanced car and is not better. In other words, just bolting up parts does little or nothing for you without knowing the effect of it. If you were only going to bolt on a FSTB you would be doing yourself an injustice IMO. With the springs,shocks,FSTB and RSB the maxima is a totally different car With just a FSTB it is a worse than stock handling car as the front pushes more. As I ramble on the point I am trying to make to .org members is either assemble the parts to get the entire job done or do nothing at all. Simply bolting on a part here and there makes no sense. Such as springs without shocks or a FSTB as your only chassis mod cause it looks cool. I also have to keep reminding myself this is a Maxima and not my little race Datsun 510 so maybe the front camber plates I wanted would be a little to much
Old Jul 3, 2003 | 10:20 PM
96_vqmax's Avatar
You should have gone with the Stillen and no rubbing on the brake line LOL,I got Stillen RSB and loving it.I think the Stillen one are very well design,just my .02$.
user 11122324
42
Jul 18, 2022 03:35 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
Noela
Sep 26, 2015 08:22 AM
homewrecker
Sep 24, 2015 07:01 PM
