Changing Antifreeze?
Old Jul 2, 2003 | 09:42 PM
thomasd cook's Avatar
How difficult is it to change the antifreeze? Is it the same as my old Max. All I had to do is turn the drain **** to release the coolant. Live in dirty south and it's damn hot. Would definately prolong life of car changing it every other year.
Old Jul 2, 2003 | 09:45 PM
BigDogJonx's Avatar
Yeap, just did this last week. I turned the ratio down to 70% water to 30% coolant. I live in ATL and need the better heat dispation. Its still the same, remove the drain plug located on the passenger side of the bottom of the radiator. Then fill back up. It will probably get 6qts out, the other 2 is still in the block, unless you remove the block radiator plugs, you wont get that coolant out, those plugs are not the easiest to get to either, one is in the front, the other is in the back of the engine near the top.
Dixit
Old Jul 2, 2003 | 10:22 PM
Thanks for the info. This maintenance is a must for the new orleans area. It gets so freakin' hot and it'll definately keep engine coolant flowing smooth. Not worried that much about the other coolant in the block.
doctorpullit
Mar 29, 2016 11:08 AM
MaxLvr21
Oct 17, 2015 12:11 PM
jds22
Sep 29, 2015 02:03 PM
Noela
Sep 26, 2015 08:22 AM
