Headlight bulb just burned out....
Old Jul 9, 2003 | 02:49 PM
POPO6SPD's Avatar
Dammit,
I just replaced my foglight bulbs and now my headlight bulb just let go. I was using the APC brand Xenon set and it looked very nice and clear at night, with that blue color to it, huge difference in visability. My question is, which brand bulb gives that nice blue-ish color and lasts? Thanks in advance.
Old Jul 9, 2003 | 03:08 PM
Y2KSESteve's Avatar
You can try a PIAA bulb. Make sure it was just your bulb that went out and that you didnt fry your harness.
Old Jul 9, 2003 | 03:19 PM
wally9mm's Avatar
The 2K owners manual says that the replacement bulb type is a "60/55 Watt HB2".
Is this the same as the Hi/Low "H4" bulb? Thx.
Old Jul 9, 2003 | 03:20 PM
Y2KSESteve's Avatar
Yes, we use H4 bulbs which have the high and low beam in one.
Old Jul 9, 2003 | 04:10 PM
POPO6SPD's Avatar
thanks guys,
I've seen the PIAA bulbs and I know they are quality but they are expensive. I really like the blue color and I thought the PIAA was more of an "intense" white?
Old Jul 9, 2003 | 05:35 PM
Y2KSESteve's Avatar
They make different bulbs which put out different color light.
Old Jul 9, 2003 | 06:02 PM
BLKMAX005SPD's Avatar
you didn't touch the light when you put it in did you...
That will **** up your light
Old Jul 10, 2003 | 10:12 PM
POPO6SPD's Avatar
Thanks for the help everyone, I'm going to get the PIAA's.
Old Jul 10, 2003 | 10:17 PM
02'maxed-out's Avatar
go with HIDs...
Old Jul 11, 2003 | 01:10 AM
Tony Fernandes's Avatar
I used to have the PIAA Xtreme whites...they burnt out in less than 2 months!! When this happened I did a search and was surprised of all the negative PIAA comments I found regarding early failure. However, I've had my PIAA ion crystal yellow fogs for over a year and they are great!
Midnight Moose has some xenon bulbs that I was referred to by another org member. I really like them...they're bright and have a blueish tint to them, and only $15.49/pair.
Whatever you get, good luck.
Eaglite H4s
Tony
Old Jul 11, 2003 | 04:29 AM
POPO6SPD's Avatar
Eaglite H4s
Tony
wow, I guess it seems whether or not youre bulbs last is luck. Last time I installed mine I did not touch them and they lasted for 7 months. Well, I guess I'll buy whatever I find tommorrow cause I hate driving aound with one light out and having everyone flash me all the time.
Old Jul 11, 2003 | 06:01 AM
PCGuRu2K's Avatar
All those aftermarket bulbs will not give you that color your really looking for. Just go buy some HID's. They have GD's going on now that sell the, for $3 bills and change.
Old Jul 21, 2003 | 11:40 PM
Johnny Vig's Avatar
I agree those aftermarket blue bulbs are a waste. They actually filter out much needed light. They may look pretty, but they are dangerous.
Go with the Philips vision plus bulbs. They use them in Europe and are great. Not blue, but tons of light.
p.s. for even more light adjust your fog lights so the beam is closer to the headlight pattern. Huge difference.
Old Jul 21, 2003 | 11:56 PM
wcasskicker's Avatar
I have 2k Max, I've been using PIAA bulb for a year now, no problem with it and it's still working fine....
Old Jul 22, 2003 | 12:10 AM
topdaytrader
Just check out http://www.motionr.com
Old Jul 22, 2003 | 12:23 PM
Yeah, I thought the same thing and tried this last year. Big mistake. I got flashed by EVERYONE. It would appear the fog lights are much more prone to blind other drivers if they're adjusted even a little.
Tony
Old Jul 22, 2003 | 03:29 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Tony
Hmmmmn...maybe that's why I get flashed. I thought it was just morons that thought my HIDs were brights, but maybe it's my fogs.
I'll have to try aiming them or leaving them off and see if it helps any. Otherwise, I'm going to get some KOPS HID bulbs or similar, so they look ricey and people don't mistake them for brights.
mpbclutch33
Dec 26, 2015 11:11 AM
knight_yyz
Nov 1, 2015 01:34 PM
Noela
Sep 26, 2015 08:22 AM
