View Poll Results: What kind of plugs did you use?
stock NGK Platinum
212
58.89%
NGK Copper
59
16.39%
other brand of platinum
30
8.33%
other brand of copper
0.83%
Denso Iridium
56
15.56%
Voters: 360. You may not vote on this poll
Replace Spark Plugs: Platinum or Copper?
Cleaning coils & boots should be simple... just wipe all carbon/junk off the outer casing with some cleaners, apply some silicone spray and reinstall the coils with a little dielectric tuneup grease to the spark plug's ceramic insulator (or a thin layer in the boot, if that's easier--just don't clog up the coil's terminal which plugs onto the spark plug's center conductor)
Cleaning the coils was something I remember from the old CA18DE engine (1988)... too much carbon down there can promote flashover, possibly making the coil fail (and causing misfire/etc.)
Originally Posted by SR20DEN
I can do it in 35 minutes.
Thanks.
's
Originally Posted by georged98
What I need to know is how difficult is it to replace the spark plugs, not how long it takes. Do you have to dismantle anything to get to the plugs? The front ones seem not too bad; how about the back plugs?
Thanks.
Thanks.
Originally Posted by Chrismuller
Someone stated that you should replace the back ones with Plats and the front with copper. Does this cause any potential issues, since they perform differently?
Originally Posted by traderfjp
I paid 57.00 for a set of 6 at Coutesy. Not a bad deal. I would stick with OEM for our cars.
went to Advance Auto part today, here is what I am found
1) oe style G-Power $2.98 2) Laser Platinum $9.98
wow there is a big difference, is it worth it?????????????????
Anybody have clue? I need to change mine 78k miles already.
Originally Posted by theMax
NO, alcohol dries out rubber and makes it crack.
The military now specs soap and water to clean the rubber gas masks, not alcholos wipes as before as the masks were developing cracks. I know that these boots are not going to protect your life but thats my 10 cents.
The masks are latex I believe. I should call my NBC NCO. I remember when they used to have the alcohol wipes in them and now you have to wash them in warm soap and water. PITA
I got triple plats
My mechanic installed 6 triple plats at 60K. Apparently that's what I had in my 00 for stock, and they were pretty covered in deposits. I won't say how much I paid for them, bcuz it may have been too much. Either way, I trust him.
I notice that I don't get as good gas mileage...it can't be because of the new plugs can it?...cleaner spark...no can't be.
Are triple platinums that much better so that they have to charge so much?
Just want to know for future reference.
You coming back to MIR next year?
Holy crap! Just went to the auto store and they wanted $20 EACH for the NGK Plats! There's no way Im spending over $120 on spark plugs. I just bought and installed NGK Plats on my mom's SAAB for under $10 for all four. I dont see how our's can be THAT special.
Just removed a couple to see how mine are doing after 50k... I've got to say they don't really look that bad. I think Ill hold off for a bit more.
BTW, the best price I've seen for these plugs are at www.sparkplugs.com for $11.71. Anybody know of a place with better prices?
Originally Posted by 00MaxSE
I heard Iridium plugs are only beneficial if you car is boosted.
Copper: Best conductor of electricity, most power, soft metal (loses gap), short life (as little as 5k on a set)
Plats: 'Poor' (I use this term loosly) conductor of electricty, Less power, EXTREAMLY hard, Holds gap, LONG life (60k on a set is normal)
Iridium: Conducts electricity nearly as good as copper, power levels near copper, As hard as plat, holds gap like plats, and their life is like plats.
Boost has little to do with the material used as the conductor. Boost/Power is important when you talk about plug gap and heat range of the plug.
I personally run Iridium's in my 3000GT VR-4 (Twin Turbo) and reccomend them to those who consider power and life important.
Copper is a better conductor of electricity than plats.
Plats will last longer but coppers give the best spark. Take your pick!
Two needles will spark more readily than two metal ***** at equal distances.
Copper plugs are crap. Copper is a soft metal that easily corrodes and has a low melting point. I would use Iridium or Plat. only. Plat plugs and esp. iridium can easily last 100k miles.
crazy hoser
Just checked my plugs and the guy before me had these stock POS plugs in there. I actually thing they are STEEL! Just kidding, I put in Champion Platinum
+4 and wow power... For $29 for the six i couldnt pass it up...
Originally Posted by carsarecool
is there a how-to?
It's really simple, unplug and remove the ignition coils, unscrew spark plugs, put new ones in, put the coils back in and plug them in. Takes 10min tops.
