IS this normal for stock springs?? with pics
Old Jul 24, 2003 | 03:34 PM
Cubanato's Avatar
Joo wanna play??......ok we go to war
I was told this should not be like this.. i have it on both springs...but i am lookign fro some answers with guys who know all about MAXIS
here are some pics
the driver side springs
Old Jul 24, 2003 | 03:38 PM
Maximam's Avatar
Your spring isolator is coming off. Not normal and your springs will get noisy.
Old Jul 24, 2003 | 03:44 PM
soundmike's Avatar
Very sound, Mike
I have some kind of rubber dangling in the same location you have yours. I've had it like that for quite a while now (i'm thinking 15k miles ago or so).
Old Jul 24, 2003 | 04:15 PM
MannyNJ2k2max's Avatar
Re: IS this normal for stock springs?? with pics
here are some pics
Damn! Have you been to a few Baja races lately! or does your max
eat way too many potholes for breakfast! I'd definitely take care
of that prob ASAP! See if thats covered under warranty-
Old Jul 24, 2003 | 04:20 PM
soundmike's Avatar
Very sound, Mike
Re: Re: IS this normal for stock springs?? with pics
Here's how mine looked... when i posted about it then the responses i got was that it was normal and is nothing to worry about.
So far i've had no problems or weird noises coming from them.
Old Jul 24, 2003 | 04:58 PM
Snolife's Avatar
What we have here is a failure to communicate
All the more reason to upgrage that stock suspension.
Old Jul 24, 2003 | 05:19 PM
szapp's Avatar
It's not normal. My 95 Max did the same thing. I fixed it by lifting the car enough to extent the spring. At that point, more of the spring is off the base plate and you can clean both the spring and rubber isolator. Use soap and water then brake cleaner on both spring and rubber islator. Make sure both are CLEAN. Go out and find a glue made by GOOP called "HOUSEHOLD contact adhesive & sealant" The glue is great stuff. It is extreamly strong and will flex with the springs. Apply the glue to the islator then use several small tie-straps to hold the islator to the spring while the glue dries over night. I did this fix three years ago and the isolators are still in place. Good luck.
Scott
Old Jul 27, 2003 | 09:49 AM
theMax's Avatar
not a big deal, just lift the spring like above and glue your rubber back on. I would go to the dealer if still under warranty.
if you go with aftermarket springs, most of them do not come with this piece and you will have to reuse.
Old Sep 7, 2003 | 09:54 PM
vm's2002max's Avatar
I have the same deal here. Both sides look exactly like the above pictures. Just waiting for the next oil change. I don't care if isn't a big deal. Nissan is fixing their f*%# up under warranty!!
Old Sep 8, 2003 | 07:47 AM
Dany's Avatar
I had similar thing happen on my 95 Max and it was fine. Never made any noises.
Now what I noticed that I have on my 2002 Max the other day, is that Upper Spring Rubber Seat is not sitting correctly on the spring. It only like that on driver side. Should I worry about it?
Also, that problem that was shown in the pics above both sides look fine on my car.
The Frye
Sep 2, 2021 11:03 AM
9aj9
Apr 5, 2020 12:11 AM
BkGreen97
Apr 2, 2016 05:47 AM
AT978
Sep 6, 2015 10:31 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
