Help with lighting
Old Jul 28, 2003 | 02:28 PM
Spin20's Avatar
Help with lighting
I recently purchased Light up door sills from custom maxima and I cant figure out how to wre them with the door lights. I can't wire them into the switch because when te door is open it cuts the power from the wire so they are off when the door is open and o when the oor is closed. N E sugestions?????
Old Jul 28, 2003 | 02:32 PM
Y2KSESteve's Avatar
You need to tap the wire that gives the door light its power.
Old Jul 28, 2003 | 02:33 PM
Spin20's Avatar
where is this wire located????
Old Jul 28, 2003 | 02:35 PM
Y2KSESteve's Avatar
Pull off the cover of the light in the door or just pull out the whole assembly as one. Use a voltmeter to check which wire has the power. There are only 2, so its one or the other.
Old Jul 28, 2003 | 02:37 PM
Spin20's Avatar
so where should I run this wire .....in the door jam???
Old Jul 28, 2003 | 02:46 PM
Y2KSESteve's Avatar
I put the black box and most of the wires behind the plastic kickpanel on the passenger side. I tapped the wires on the passenger side. I ran the connecting wire to the other plate under the floormats, behind the dash, under the driver side floor mat to the other sill.
Old Jul 28, 2003 | 03:06 PM
Spin20's Avatar
so where did you connect all your wires to??? I grounded mine and put the power to that light in the door and for some reason its a continuous power??
Old Jul 28, 2003 | 03:17 PM
Y2KSESteve's Avatar
I have pictures of my install at home. If I remember I'll get them posted and they should help you out a bit.
fastcarny
Oct 6, 2015 10:42 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
