Belts
Old Aug 4, 2003 | 12:12 PM
stose95's Avatar
Belts
Anyone have a how to on changing the two drive belts for the 2000 year?
Old Aug 4, 2003 | 02:51 PM
[maxi-overdose]'s Avatar
hmmm..no how-to. but I can tell you how.
1.jack up the car.
2.take off the front wheel on passenger's side
3.take off splash guard
4.loose the nut that holds the pulley on the tensioner adjuster. it's a 14mm nut.
5.use a 10" extension with 14mm socket, turn the belt tensioner adjuster counterclockwise to loose the belt (from the top, it is located right infront the engine mount on the passenger side). to make sure you have the right direction I would do 5 turns and then check the belt to see if it is loose.
6.once it is loose, take it off and put a new one in.
7.tighten the nuts that hold the pulley a little. makes sure it is tight enough and the pulley does not wobble but you will be able to slide it up and down. Make sure the bolt that holds the pulley is locked into the tensioner adjusting plate.
8.adjust the belt tension. do a tension test bending the belt: bend the section between the crank and AC, it shouldnt be bent over 90 degree.
9.start the car and watch the belt make sure it does not run off the pulley.
10.put everything back.
Old Aug 4, 2003 | 02:55 PM
Re: Belts
the other belt is not a drive belt, it is a powersteering pump belt. I wrote a how-to:
http://forums.maxima.org/showthread....highlight=belt
Old Aug 4, 2003 | 05:29 PM
stose95's Avatar
Thanks guys!!
You have been more helpful than the haynes manual I bought this weekend.
I will give it a shot this coming sat.
Old Aug 4, 2003 | 05:45 PM
Thanks guys!!
no problem....Hayne's manual on the drive belt is applicable for 2k/2k1. but the powersteering pump belt replacement instruction on the Hayne's manual is for 4th gen only.
Old Aug 6, 2003 | 07:16 PM
Mom's2kGLE's Avatar
thanks maxi-overdose for the write up, the haynes says nothing about loosening the pulley nut. Did mine today piece of cake and I didn't remove the wheel I had it on a set of ramps. Thanks agian.
Old Aug 6, 2003 | 08:30 PM
no problem~ good to know that everthing went well. yea, if the nut on the pulley is not loosen first, it will crack the pulley adjuster.
05' MaximaMan
Oct 8, 2017 06:36 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
markevans999
Oct 25, 2015 08:27 AM
homewrecker
Sep 24, 2015 07:01 PM
2kmaximel
Sep 24, 2015 03:55 PM
