How To Remove The Stock Shift Knob?!
Old Aug 4, 2003 | 02:37 PM
beejo's Avatar
How To Remove The Stock Shift ****?!
HI PPLZ....MAH BABY IS A 2002 MAXIMA..I AM JUST WONDERING IF ANYONE MAXIMA FANS OUT THERE KNOW HOW TO REMOVE SHIFT ****...COZ I WANT TO REPLACE THE STOCK SHIFT **** WITH A MOMO SHIFT ****...AND MAH CAR IS AUTOMANIC...THANKS PPL!!!!
Old Aug 4, 2003 | 02:38 PM
MAKSYMALNY
All you have to do is twist it right off... lefty loosey, righty tighty.
Old Aug 4, 2003 | 02:39 PM
MiniRX7's Avatar
TWIST.. mine came loose over time
Old Aug 4, 2003 | 02:45 PM
beejo's Avatar
THANK YOU GUYS...
BUT THEN I TRIED THAT BE4...IS DAT THE WAY ONLY FOR MANUEL?
COZ MAH MAXIMA IS AN AUTO. SE..
THE SHIFT **** IS LIKE GLUED!!! NO IDEA HOW TO DO IT!!?!
Old Aug 4, 2003 | 02:47 PM
MAKSYMALNY
Umm... mine is an Auto and I easily twisted it right off when I replaced it.
btw, beejo... lay off the CAPS!
Old Aug 4, 2003 | 03:55 PM
Pir8 97's Avatar
and the phonetic slang. This isn't a Honduh forum
Oh, welcome to the org!
Old Aug 4, 2003 | 04:33 PM
beejo's Avatar
mmm....pplz...I still can't take off the STOCK SHIFT ****..becoz it's really really tight....and I am wondering which way should i twist the thing?! if you guys have any pic which can show the way to do it...
pls let me know....THANK YOU VERY MUCH GUYS!
Old Aug 4, 2003 | 04:57 PM
artigor's Avatar
Where did you get yours? Price?
Old Aug 4, 2003 | 05:35 PM
spirilis's Avatar
Heh on the same topic, my manual shift **** is tight as HELL.
I tried using adjustable pliers with electrical tape around the teeth, but the teeth ended up digging a small scratch in the leather shift ****...
I've tried with both hands REALLY tight on the **** to move it... damn thing won't budge. Not a big problem, as I'm fine with the stock shift ****, but it'd be nice to loosen it in case I wanted to replace it (with one whose shift pattern emblem wasn't faded off, and one that doesn't have scratches in it as a result of me trying to remove it with metal tools...)
Old Aug 4, 2003 | 05:44 PM
BLKMAX005SPD's Avatar
Mine shift *** was glued too...
I had to cut it and heat it up to ghet that **** off...
Its was a pain in the ***
Old Aug 4, 2003 | 05:45 PM
iLLin-2k1's Avatar
^^ whimps! ^^
Old Aug 4, 2003 | 07:27 PM
young1976's Avatar
Use a Pipe wrench. These are the red handel ones with a big adjusting wheel thing. Make sure it's got a long handle and wrap the **** with some rubber sheets or towel and turn counter clockwise. The long handle give you leverage and it comes right off. They are glued to keep them on.
Old Aug 4, 2003 | 07:33 PM
jay beede's Avatar
use a strap wrench--available at sears, osh or harbor freight. it will take the **** off without damaging it. also useful for tightening/loosening any delicate or finished threaded objects.
The Frye
Sep 2, 2021 11:03 AM
9aj9
Apr 5, 2020 12:11 AM
Mar 12, 2020 12:06 AM
trailer54
Nitrous
Nov 18, 2015 07:44 PM
Colossus
Sep 9, 2015 05:46 AM
