Go Flush Your Radiator!!!
Originally posted by Jeff92se
Hmm we are getting into that car knowledge thing here JT
Radiator, you can have it pressure tested and visually inspected for cleanness. A clogged up radiator will look like total crap if you look inside it. A unit with clean fins/tubes would most likely NOT be clogged. But a flow test could verify that also.
Belts. You can inspect for obvious wear. But an old belt that looks to be in perfect condition can go with no warning. And since any strength test would essentially ruin the belt, it's not really testable.
Please paypal $20 to my address............
paypal $20 to MY address
Buahahhahahahahaha! Your logic is
It's WAY too funny to see you keep asking. How you be a 5-gen onwer and NOT know Ruskles?
Originally posted by MAKSYMALNY
Same with the belt.
and you ignored my question.
Same with the belt.
Hmmm... dunno.
Reason why is, my name is ROSS, not Russ.
Originally posted by 2002 Maxima SE
What did your radiator fluid look like when you flushed it the first time? If it was brown in color but still flowed like water...coolant was old and filled with rust. If it has patches of brown sludge, that could be oil in the coolant. FYI
Originally posted by jttaylor155
it had LOTS of brown rust flakes.
oil is fine. not losing any at all.
okay my radiator pressure tested fine, coolant looked fine, radiator itself looked fine. but it was still clogged. yes out of the ordinary but diffirent things happen.
Oh boy.....
to heck with it... instead of worrying about maintenance schedules, I'm just going to buy a new car every month.
That SHOULD do the trick.
you do know that you can flush it yourself for about 10 dollars right
so i could save that money and get one every 18 years. so you are right, i wont flush it again, ill just get a new one in 2021. im sure ill still have my car then
To do it right you have to get the car up to temp to flush out the block.
To tell people to do this themselves with out collecting the coolant is just wrong also. This stuff is worse than oil, it's harder to collect and there is a lot more of it. This is just one of those jobs that is best done at a shop, even if you buy your own coolant.
that wasnt causing the block. if so that would have fixed the problem. by the time i flushed it there was so much blockage that a flush couldnt get ride of it. (think clogged artery) yes after i flushed it had some flakes but the coolant looked fine. the flakes were not enough to cause the problem.
Jeff isn't going to change what he believes, whether it is a pink elephant or not.
Just know that you and I, JT, are correct in our approach.
Ah riiight.. And exactly what do you think CLOGGED the radiator?? All the stuff in that fine looking coolant??
If you had all the junk in there, maybe the coolant wasn't all that "fine". Because if it was "fine", You wouldn't be getting all those "RUSTY FLAKES" in the coolant.
that wasnt causing the block. if so that would have fixed the problem. by the time i flushed it there was so much blockage that a flush couldnt get rid of it. (think clogged artery) yes after i flushed it had some flakes but the coolant looked fine. the flakes were not enough to cause the problem so the "look at the coolant" is cr@p".
Originally posted by maximaman777
Umm yes I do know that. But I'm lucky and have a good friend that owns a shop. Even if I didn't have that option it's not something I would do myself for the simple fact that disposal is a PITA. I have a dog and there are many kids in my N'hood, that and it's just not right to dump it down the drain. I live to much respect for the environment for that.
i think you dont do it cause you are lazy and/or dont know how to do it. (BTW the radiator is that flat thing in front of your engine to cool it off)and yes to do it right you need to get the car up to temp. thats what i did. "drain the coolant then put in the flush liquid. run the car with heater on till each reaches operating temp then 10 minutes longer. then drain, fill with water and repeat till water comes out clean"
Damn, you drain your old oil into the street drain also??
im sorry mister tree hugger
It is my hope that if it's any of the animals that die in your area it's your Fuking dog or cat. and not one of your poor neibhors, how I pity them for living near such a schumk.
I guess you don't do any fishing in Reston. DO YOU, YOU USELESS ***.
SHUT THE *** UP YOU
tree hugger.IT WAS A JOKE!!! did you not read the post right before that where i said
"i take my coolant and oil to a parts store where they dispose of it"
SHUT THE *** UP YOU
tree hugger.
SHUT THE *** UP YOU
Since when Nissan mechanics that great? buhahahaha You mean how they did an expert job on my car?? ahahahahahahhaa funny you are.
You are basing my knowledge off of telling someone to change their coolant after "awhile". Pot Kettle Black You
so i guess you think you are smarter then nissan mechanics??
now i really know you are full of it
SHUT THE *** UP YOU
tree hugger.
SHUT THE *** UP YOU
And well all get to here about this next year when you do it again
JT... don't be so close-minded. You represent a man in uniform... someone who should be more "world traveler" and cultured.
Yea right and you catch the coolant fron the block just as the thermostat opens or you just keep collecting the water as it come out so you can take 10 gallons of chit to the parts store.
again i started this thread to help people out so they wouldnt have to replace their radiator then JEFF started arguing with people about how often you have to do it. i really dont give a **** about that. i just wanted to give people a heads up.
how am i closed minded? it was a joke and i was telling him to get over it. and as far as world traveler...i have traveled more then most people will in their lifetime.
by the way i just got a private message. so i helped someone out. everyone else can blow me
Hey I just read that huge thread regarding the radiator flush. First off, congrats on fixing your car! Glad it worked out for ya. Second, man who the he11 does Jeff think he is? The more posts I read from him the more I think this guy needs help. He hasn't got one good thing to say about anything. Always finding the negative and ripping somebody. Your thread was a good piece of advice to some and your experiance with an overheating problem was finally solved. It's good info in there and Jeff shot it down. Sometimes I wonder how these guys go to be moderators in the first place, he surely doesn't do this site any good.
Hmmm... I've been to 19 countries, how about you?
coutries - 12 or 13
number of trips?? well in the last 6 years, 9 trips to saudi (90 days each) 8 trips to turkey (again 90) and about 5 to classified locations. plus my dad was also in the military so we traveled ALL the time.
Odd no names = no creditability. If you don't got the ***** to come out here and say something, then don't.
So since you posted it you must agree. Anytime you want to compare posts(me vs you) and see who tries to help more people, I'll take that bet too. Same goes to the no namer in the PM
Last time I remember, you were busy posting rice mobiles in this forum
okay do you mean number of countries or actual trips.
coutries - 12 or 13
coutries - 12 or 13
I've visited 19, you've visited 12 or 13. TRUMP!
You've traveled more, I've SEEN more. HAH!
and yes i post rice mobiles cause i know we ALL get a kick out of them.
smooches BIATCH
What's the difference? trips are trips, countries visited are countries visited.
