NE 1 trim there bump stop when lower with the H&R!!!!!!!!!
Old Aug 17, 2003 | 11:33 AM
96_vqmax's Avatar
I bought a set of H&R from an org member,so mine doesn't come with install instruction.So I just want to see if ne1 install the H&R with GR2(that's what I got already) cut there factory bump stop or get aftermarket one?Any input is appreciate.
Old Aug 17, 2003 | 01:57 PM
SilverChrome03's Avatar
Do not cut your bump stops. H&R instructions does not call for it. I have this setup on my 5th and it works great.
Bob
Old Aug 17, 2003 | 11:24 PM
96_vqmax's Avatar
Bob
So are you using your stock bump stop right now.I remember when I purchased my Eibach for my 4th gen.The instruction does said cut your bump stop about 1 and 1/2 in off. Does ne1 know why the H&R doesn't require to cut the bump stop(was this for 5 gen only),or was it that the drop is less than Eibach so it doesn't need to cut the bump stop?Thanx for your help.
Old Aug 18, 2003 | 04:57 AM
The bump stops on my car are stock and uncut. Could be a different spring rate or drop for the Eibachs ?
I'm a stickler for reading instructions, and i remember clearly that the instructions out of the box did not call for it: Take old springs off and install new with all the original components as is.
My car has a great ride and is actually smoother than stock SE with less body roll.
Bob
The Frye
Feb 3, 2019 08:34 AM
Turbonut
46
Oct 21, 2015 08:28 PM
tgreen
Oct 18, 2015 06:18 PM
pears
Sep 18, 2015 05:25 AM
brichi
Sep 14, 2015 05:23 PM
