are underdrive pulleys worth getting???
Old Aug 21, 2003 | 04:11 PM
harmbone2k2's Avatar
6yrs old=36,500 miles :)
I am wanting to get an underdrive pulley for my 2k2. I am pretty new to all the upgrading so are they worth it? What is the best one to get and how easy are the installs?
Old Aug 21, 2003 | 04:18 PM
92 SE-R 02 SE
according to SR20DEN...NO
Old Aug 21, 2003 | 06:59 PM
y2kse's Avatar
According to me, yes. Combine the UDP with a timing advance and you'll definitely feel the difference. Or, of course, you can just hang in there with naysayers and wonder who's really right.
Old Aug 21, 2003 | 07:23 PM
2k2PhatMax's Avatar
Sold 2 99Silvermist SE :)
yes...........
Old Aug 21, 2003 | 08:27 PM
maxy03's Avatar
WELL IF YOU HAVE AOR ARE GOING TO INSTALL A SYSTEM THEY DO NOT RECOMMEND TO INSTALL A UPD. IT IS DIFFERENT IN SIZE CAUSING SOMETHING TO THE ALTERNATOR WHICH PRODUCES POWER=OR SOMEHTING LIKE THAT. I SAW AN ARTICLE IN A MAG. SORRY FOR THE LIMITED INFO
Old Aug 21, 2003 | 08:58 PM
ok what system would be talking about? and what does a timing advance do and where does it go?
Old Aug 21, 2003 | 09:52 PM
Ghase's Avatar
He talking about a sound system, I'am also thinking about the udp too, but I have a 800 watt kenwood amp computer fan with two kenwood 12's.!!!!! So I don't know!!!!
Old Aug 21, 2003 | 10:01 PM
KCMichaelM's Avatar
UDP is worth it peformance-wise. It has the same effect as installing a lighter flywheel on a manual. You have to put in a LARGE audio system (1200+ watts at least) to make a difference in power.
Old Aug 21, 2003 | 10:17 PM
MAXINXS's Avatar
I am a believer!
Old Aug 22, 2003 | 04:24 AM
so kc, i need a new flywheel since i have a 6-speed?
Old Aug 22, 2003 | 08:45 PM
bigdo26's Avatar
new flywheel is different than an UDP. with a 6 speed you can get both, which will reduce engine lag even more. For an auto 2k2, I like my UDP and definatly notice a difference. When I raced a 2k2 SE auto at the track, I pulled on him thru 1st gear, and nothing else... this is apparently due to the UDP as it makes the biggest difference in 1st gear. As far as the stereo system thing goes, I have a system which has been completely unaffected by the UDP. Also, the A/C works as good as ever, but there is noticably less power loss when I'm running the A/C after installing the UDP. If you install it yourself, then ya, its worth the money. It certainly doesnt make the car any slower!! That just is not a possibility because of what the UDP does. So go for it if you gots the money
Old Aug 22, 2003 | 08:48 PM
and i need new belts too right? would autozone be a good place to get those?
Old Aug 22, 2003 | 10:07 PM
Virus's Avatar
I feel less power loss when the A/C is on. I notice no headlight dimming with my $3k audio system. Nice low end power increase.
Old Aug 22, 2003 | 10:56 PM
SeaFoam2DMax's Avatar
Oh hi....
I've seen at least three diff brands of UDP, what are the main differences?
Who makes a lightened flywheel for 5th gen 6spd?
I'm new please excuse the stupid Q's
Old Aug 23, 2003 | 08:03 AM
KCMichaelM's Avatar
I have Unorthodox, they have been pretty much "the" UDP since the idea came about years back.
Earlier I meant UDP and flywheel have same weight effect on engine (a UDP is much lighter than a stock pulley), but yes UDP's do gain a lot from underdriving components too. If you have a manual, you'll notice your revs drop quicker after clutching with a UDP, and much more so with the lightened flywheel. I had a light flywheel on my 300ZXTT, and I highly recommend it. I love how it makes the car shift. I can't comment on the flywheel vendors, I used Stillen for my Z and was happy.
Old Aug 23, 2003 | 09:47 AM
asu174's Avatar
Clay Aiken has fancy genitals
Mine was a waste of money on my 2K. I felt nothing.
Forge277
Jun 13, 2016 09:26 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
02PearlSE
Feb 1, 2016 12:37 AM
rbarnes
Dec 31, 2015 06:29 PM
