breather filters.....
Old Sep 1, 2003 | 08:43 PM
TitaniuMax03's Avatar
I think I might have a good question..well I just installed my JWT intake last week and love it...well I was showing one of my friends yesterday and asked why is there no hose connecting to one of the open tubes leading into the engine...well I told him once I took off the stock airbox and put the JWT in there was no other end to connect the tube to...he told me that I need something to cover it cause dirts gonna be sucking into the engine...is this true? can I use one of those little breather filters in it?
Old Sep 1, 2003 | 08:50 PM
to be more specific heres a pic..not of my intake though..the part Im talking about is where the silver rubber hose connects from the intake to the engine, right under the engine cover
Old Sep 1, 2003 | 10:02 PM
VMaximus02's Avatar
I had the same question about that hose before...couldn't find anything to connect it to. My mechanic told me that it's a air release hose for the transmission and should be kept unplug. FYI: My mechanic works for a Toyota/Lexus dealer so I am not sure if his answer is correct?
Old Sep 2, 2003 | 05:14 AM
PCGuRu2K's Avatar
You should put a breather on their because there are very lil deposits of oil that come out from there. Just get one of those $5 crank case breathers.
Old Sep 2, 2003 | 07:01 AM
I found these at 2Kracing.com for only $12, should they work??
Old Sep 2, 2003 | 08:12 AM
MaximaMan77's Avatar
http://forums.maxima.org/search.php?searchid=662
Old Sep 2, 2003 | 08:54 AM
Blu's Avatar
Blu
the tits
just get one from pep boys or autozone...
Old Sep 2, 2003 | 09:18 AM
bglandon23's Avatar
sorry to steal the tread but where did you buy your weapon intake
Old Sep 2, 2003 | 10:18 AM
SR20DEN's Avatar
VQ Wizard
Those breathers need tap into the main intake from the MAF for a reason. If you just put some stupid filter on it your engine will suck through unmetered air and perform more inconsistantly.
Old Sep 2, 2003 | 10:31 AM
2k2PhatMax's Avatar
Sold 2 99Silvermist SE :)
i put one on mine... can u explain more whys its bad?
Old Sep 2, 2003 | 11:55 AM
Several people here have one and not had any problems. Why? I don't know because I'm not one of them.
check out this thread.
Old Sep 2, 2003 | 12:10 PM
MaxDoogie's Avatar
the $5 ones from pep boys won't fit on the crankcase, the joint is too small to fit over the piping...Kev got a K&N one that worked perfect, you may want to PM him and ask what he got
Old Sep 2, 2003 | 12:24 PM
Blu's Avatar
Blu
the tits
they will with a little trimming
Old Sep 2, 2003 | 02:49 PM
hct67's Avatar
CustomMaxima.com
I brought it at CustomMaxima.com
Old Sep 2, 2003 | 03:31 PM
ynot411's Avatar
Air Breather Filter
I purchased an air breather filter when I first purchased my car. After 1 day of driving my SES Light came on. The reason I received the SES was because the air going into the crank case was not metered air (meaning air that has passed through the MAF Sensor.) Our engines and sensors are very sensitive to mods such as an air breather and in my case and others the car rejects them. *PLEASE NOTE not all 2002-2003 Maximas are affected right away or even months down the road...it is not recommended and is not known to improve performance. My opinion is from my personal experience with this particular mod.
Old Sep 2, 2003 | 03:52 PM
2k2PhatMax's Avatar
pepboys fit mine fine....
Old Sep 2, 2003 | 04:44 PM
MaxDoogie's Avatar
hhmm...I wonder why I couldn't get mine to fit...did you guys get the APC brand one, or something different? the tubing was way too small on the one I got, I greased that bad boy up, and I still couldn't get it to slide on
Old Sep 2, 2003 | 05:45 PM
Originally Posted by maximaman777
thanx..I tried that and nothing helpful showed up for me...so Im hearing "no" dont get the breather cause it will throw me a SES light and "yes" it works...if not than what will be worry free??
Old Sep 2, 2003 | 06:49 PM
2k2PhatMax's Avatar
no ses here... but i guess everyones car is different
Old Sep 2, 2003 | 08:51 PM
02VQ35's Avatar
I had a K&N Breather Filter on mine and no problems. I was told that all that port does is help increase exhaust flow. I've since put the stock airbox in and reconnected the stock hose. No problems still. Chris
Old Sep 3, 2003 | 06:33 AM
The only thing I can think of that makes any sense to me as to why some people have problems and others don't is the level of mods you have done. Maybe with a freer flowing setup it's more prone to running lean. Elevation where you live may also play a part.
I was getting random misfires because I was running lean, even at idle. As soon as I took it off it went away. As adding one of these does nothing for performance I'm not worried about not being able to use one.
If you want to try and keep your TB & intake manifold cleaner try an inline filter. It maybe prone to clogging over time but they're easy to install and cheap.
There are also more elaborate filters like these:
LEIF® Reservoir Breather Breather Tank Kit
Old Sep 3, 2003 | 06:43 AM
SR20DEN's Avatar
VQ Wizard
Someone told you wrong.
Old Sep 3, 2003 | 04:21 PM
02VQ35's Avatar
So what is the port for SR20DEN? Perhaps someone told you wrong.
MaximaDrvr
Aug 19, 2015 08:20 PM
SG01MaxSE
Dec 22, 2002 11:41 PM
HLMAX
Sep 21, 2002 02:47 PM
Nismo
Sep 7, 2001 10:26 PM
Zprime
Jan 19, 2001 01:42 PM
