"SERVICE ENGINE SOON"
Old Sep 16, 2003 | 12:12 PM
bluz cruz's Avatar
I have a Y2K GLE and the light came on for a couple days. I diconnected the battery overnight to reset. Three days later came on again. Figured there was a problem and made an appointment to take her in and the light went out the night before I was to take it. Seems to be running fine. 63,000 miles and coils all changed recently. Is there a chance she is still holding a code ???? Hate to take her in and spend $$ for nothing. Any suggestions
Jim
Old Sep 16, 2003 | 12:52 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
Jim
have autozone pull the code for free or take it to a local mechanic. most likely the mechanic will charge less for it but autozone is the way to go. since the coils were done, i would tend to think oxygen sensor since they have an high failure rate on some 2k and 2k1. only way to know is to have it pulled though. there are some codes that wont trip the cel and are just stored as well.
Old Sep 16, 2003 | 12:53 PM
Blu's Avatar
Blu
the tits
nice sig
Old Sep 16, 2003 | 01:27 PM
looslip's Avatar
Horra!!
Originally Posted by blubyu2k2
nice sig
Yeah, whats that, the west side of North Carolina?
Old Sep 16, 2003 | 01:42 PM
Blu's Avatar
Blu
the tits
Old Sep 16, 2003 | 03:38 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Old Sep 16, 2003 | 04:49 PM
Pir8 97's Avatar
Did you check the gas cap? If its not tight then it will throw a light.
I've read about that happening to folks on here before. A guy at work told me he was taking in his wife's Pontiac today b/c of a SES light but there were no symptoms. I told him about the gas cap thing too... he tightened it but the light didn't go out immediately. When he came back from the shop he said the computer code showed the gas cap had been loose at 2 different times in the last 120 days.
Good luck!
Old Sep 16, 2003 | 06:47 PM
Blu's Avatar
Blu
the tits
Originally Posted by IceY2K1
j00 laughin at me?
Old Sep 17, 2003 | 04:50 AM
bluz cruz's Avatar
Thanks I'll check it out...
Old Sep 17, 2003 | 04:51 AM
bluz cruz's Avatar
Good luck!
Cap was tight each time.....Thanks for help
Old Sep 17, 2003 | 06:10 AM
SkoorbMax's Avatar
I've heard of cap loose causing this as well. I'd bet it's an O2 sensor. Autozone can pull the code. I went to two when I had the problem. First could not get a reading from my computer, but the other autozone (with a higher quality reader) had no problem. Resetting by disconnecting battery would only fix it for a few hundred miles, then the light would go back on. So I changed sensor and have been good for 15k.
Old Sep 17, 2003 | 05:46 PM
87MAX4ME's Avatar
SkoorbMax,
How much did the sensor cost? Was it easy to replace? According to Autozone, I have a bad sensor (bank 1 sensor 2 [rear]).
shilov
Feb 19, 2024 09:40 PM
Pixel
Sep 15, 2015 05:53 AM
seesole
Sep 14, 2015 12:38 PM
Steven Orozco
Sep 12, 2015 10:41 PM
jfl330
Sep 4, 2015 01:44 PM
