can someone do a writeup on wiring a switch up to the drop resistor mod?
Old Oct 16, 2003 | 06:48 PM
skandalouz's Avatar
Old Oct 16, 2003 | 08:19 PM
MacAlert's Avatar
All you have to do is disconnect the plus thats on the LEFT sturt tower.
Old Oct 16, 2003 | 11:37 PM
maseo77's Avatar
?????? does this go for 2k's also?
Old Oct 17, 2003 | 04:52 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
he is talking about wiring up a switch so you control when its on and off from inside the cabin. i dont know many people running around all the time with it unplugged. most people would just be interested in wiring it up to a WOT switch like jime has. this will work on 4th and 5th gen auto transmissions.
Old Oct 17, 2003 | 06:35 AM
skandalouz's Avatar
exactly....
i was hoping to put a switch inside my cabin so i can jus turn it off when i want.. and for normal driving... have it back connected.... there were a couple people that have done that.. but as i am an electric newbie.. i dont kno the first thing about how to do it....
Old Oct 17, 2003 | 07:47 AM
woosh's Avatar
I haven't done this but I think all you need is a SPST NC switch (single pole single throw, normally closed, 2 or 3 contacts, if 3, the 3rd is usually not connected).
SPST NC: A___B
when pressed: A_/_B
Then cut only one wire going to the drop resistor. Attach one cut side to side A of switch and the other cut wire to side B. A WOT switch is probably best for this because it will only switch in at WOT and out otherwise.
hope that helps
SHIFT_woosh
Old Oct 17, 2003 | 08:33 AM
03BlkSETE's Avatar
Check out this thread. Look at the post by Jime
http://forums.maxima.org/showthread.php?t=255799
The Frye
Sep 2, 2021 11:03 AM
captchaos
Mar 15, 2016 12:18 PM
Jamie Bowen
Sep 6, 2015 09:59 PM
dcardello
Sep 3, 2015 11:44 PM
