Squealing sunroof
Old Oct 19, 2003 | 09:18 AM
Maximax2's Avatar
Squealing sunroof
My sunroof has started squealing / squeaking when it's opened or closed. Sounds like maybe it's the rubber weatherstrip rubbing, but can't tell. Has anyone else encountered this? I've tried rubbing it down with the grease that's already there, but no luck. Thoughts?
Thanks!
Old Jul 13, 2008 | 09:22 AM
hi-tek22's Avatar
bump
i need assistance with this one myself....my sun roof squeaks ONLY when closed, when its tilted open, NO SQUEAKS......
is there a type of grease, solution, or something i can use to get rid of this, replacing the weather stripping around the actual glass, IS NOT an option for me
Old Jul 13, 2008 | 03:11 PM
kcxd35's Avatar
I also am having the same issue, Mine squeaks when opening/closing just a little bit but that little bit is annoying...So bump... =O)
Old Jul 13, 2008 | 05:19 PM
baberabbas's Avatar
Just try the old lubrication trick if not i have heard that the weather stripping might be the issue..
Old Jul 13, 2008 | 07:11 PM
irish44j's Avatar
retired moderator
use some white lithium grease on the rails in inner lip of the sunroof opening. That did it for me.
Old Jul 13, 2008 | 07:24 PM
lowincash's Avatar
No More Maxipad
mine had a bit of squealing too but that went away...now when it's tilt or opened it's always rattling when i hit a bump and stuff...kinda annoying =/
bigdogsteve
Jan 31, 2018 04:18 PM
Fbana41
Aug 29, 2016 12:18 PM
Forge277
Jun 13, 2016 09:26 PM
jonreidhead
Jan 6, 2016 09:38 AM
Vequity
Sep 10, 2015 05:26 AM
