Y-pipe installation question.
Old Oct 25, 2003 | 02:57 PM
-Red-'s Avatar
I wanted to get an idea as to how did you guys install your y-pipes. I have the car up on the ramps, and I barely have enough room to maneuver in there, much less remove, the stock pipe then install the Cattman. I'm wondering how many people managed to get away with installing it, but simply having it up on the ramps and/or floor jack, versus those who ended up going to the shop. Having installed my cattback with relative ease, I was hoping this wouldnt be that difficult of a project, put the lack of space is a bit hard to overcome. Any tips are appreciated, even the ones that suggest I take the car into a shop
Old Oct 25, 2003 | 03:03 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
dont take it to a shop, its not worth your money if you're pretty good with your hands.
I would suggest putting the car up on jack stands and putting it up pretty high. Install is fairly simple. 9 bolts off, 3 new gaskets on, 9 bolts back on...
Old Oct 25, 2003 | 03:08 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i knew a buddy of mine that has a small shop so i had access to his lift. im pretty short at 5'10 but i wouldnt want to do a y pipe install on ramps. i had enough trouble with room trying to wrap the y pipe on ramps. it will just go alot easier on a lift espically if you have air tools.
Old Oct 25, 2003 | 03:13 PM
-Red-'s Avatar
Yeah, thats sort of my problem, I only have access to ramps and a small floor jack. I hate the thought of paying some clown $50+ to do this only because I dont have a way of lifting the car up to do the work myself
Old Oct 25, 2003 | 07:28 PM
PoLo's Avatar
2-Wheelin it...
be patient and you can do it bro...i did it on ramps and i had no troubles. yes the bolts are tight, but i used a 5 foot breaker bar....those bolts didn't stand a chance
Old Oct 25, 2003 | 07:32 PM
-Red-'s Avatar
Cool, good to know.. I'm going to give this another try on tuesday. I have 2 sets of ramps, so I'm going to pull the car up on the 2 up front, then jack each side of the rear and slide a ramp underneath as well, hopefully that'll give me enough room.
2kmaximel
Sep 16, 2015 03:19 PM
conansriver
Sep 11, 2015 10:26 AM
Violator
Sep 9, 2015 10:14 AM
