Air Mass Flow
Old Nov 3, 2003 | 01:39 PM
reldridge's Avatar
Air Mass Flow
I'm new to the site. A friend pointed me to it.
Anyway, I have a 2000 Maxima that is not running well. If you are running along around 45mph and punch it like to pass someone, the engine simply has no horsepower. You can let off of it a little and it seems to pick up speed slowly. The Service Engine Light (SEL)was on until I took it to the dealer. The first said it showed an O2 sensor problem. I tried to save some $ and had a local NAPA shop check the codes and order the sensor (Bosch brand) for Bank 1. I picked up the vehicle and didn't see any improvement at all. Now the SEL is back on so I took it back to the Nissan dealer and now they are saying I have to replace the Air Mass Flow (sensor/valve?). Anyway, I'm obviously not a mechanic but my friend said to clean it with carborator cleaner and lots of times it will take care of the problem.
Is this true?? If so, where do you find this valve/sensor? Has anybody else had a similar problem?
Thanks in advance.
Rick
Old Nov 3, 2003 | 01:49 PM
spirilis's Avatar
Yep, my dad's old Mazda 626 threw SES codes about the O2 sensor (and "System too lean") frequently, turned out to be a dirty MAF... though his car's issues still aren't fully resolved
The MAF sensor is inside a tube in the intake tubing, it has a wiring harness with a 6-pin-wide connector. Remove that tube (requires removing the airbox/etc.), and see if you can spray down the small wire inside there with some Air Intake/Throttle Body cleaner (carburetor cleaner may work...)
Be very very careful, as it is a very delicate sensor. Don't touch it with anything and don't spray it too hard. Also, I had to spray through some metal mesh guard that sits in front of it, so it might be a little tricky.
Old Nov 4, 2003 | 04:17 AM
MaScott's Avatar
I was able to get my MAF sensor out of that tube and actually clean it with a Q-tip soaked in carburetor cleaner fluid. I think I messed the MAF sensor up because after I did that the car started running weird (is that possible??). The RPMs do not raise above 2000 rpm, even when I floor the accelerator. Moreover, the whole engine starts shaking when I attempt to do that. Scary ride...
I measured (backprobed) the output signal of the MAF sensor, it shoud go up from 1 V to approx 3 V when the rpms go up, but it does not...
Old Nov 5, 2003 | 08:39 AM
bradqr's Avatar
Have a 2002 with 45K. The MAF went out without any hard driving. I did some research and this is what I found:
http://www.bba-reman.com/throttle_body.htm
Total cost is:
$80 tow fee
$90 diagnostic test
$480 New MAF
$140 Labor Hours (still to be determined)
Old Nov 5, 2003 | 09:12 AM
MaScott's Avatar
Total cost is:
$80 tow fee
$90 diagnostic test
$480 New MAF
Sorry to hear about all these costs. If I lived in a city with a decent public transportation system, and my MAF repair could wait for a week, i would have bought a new MAF from:
http://www.nissan-auto-parts-dealer.com/
($100 savings compared to the local dealer price), and definitely done it by myself, saving on labor - there are only 2 screws you need to take out to replace the thing, and nothing else is in the way.
Old Nov 5, 2003 | 12:44 PM
skalberti's Avatar
I live life on the edge
It's not the MAF. I changed mine $300 and still have the same problem. Probably the coils
Old Nov 5, 2003 | 01:08 PM
K1maxima02's Avatar
Total cost is:
$80 tow fee
$90 diagnostic test
$480 New MAF
MAF really sucks on 2002 maximas. I also have a problem.
Old Nov 7, 2003 | 05:17 AM
MaScott's Avatar
One important lesson I've learned this past week - when attempting to clean your MAF sensor, NEVER TOUCH the wires that are inside of the plastic tube. I happened to touch them while cleaning and the result was - a broken filament that senses the air flow. Hence, a $500 repair.
Old Nov 7, 2003 | 06:17 AM
PoLo's Avatar
2-Wheelin it...
are we all talking about the SENSOR only.
cause if memory serves me right, most of us know that yes, the dealer does charge $500+ for a new MAF, but you can avoid all that by simply getting the sensor INSIDE the MAF housing. that piece only costs $75 and is the piece that you need to replace.
yes, if you can't go above 2k rpm w/out having trouble, then you do have an MAF issue. the dealership SHOULD replace it if you're within warranty, but if not, then order the sensor only for $75 (Dave Burnette at south shore nissan 888-254-6060) and replace it yourself.
Old Nov 7, 2003 | 06:29 AM
Spartan5's Avatar
My service guy and technician told me that the ECM has to be reprogrammed with some software they download after the install of a new MAF. WTF, is this true?
Old Nov 7, 2003 | 06:31 AM
PoLo's Avatar
2-Wheelin it...
part of the TSB is to install a new maf and upload new software, but neither is NEEDED for the other to function.
i can blow my maf tonite, put a new sensor in, and the car will be back to normal.
Old Nov 7, 2003 | 07:14 AM
MaScott's Avatar
What is the part number of that INSIDE sensor? Do you know?
Old Nov 7, 2003 | 07:16 AM
PoLo's Avatar
2-Wheelin it...
just call dave burnette, he'll tell you everything
he's sold a lot of these. his number is in 1 of my previous posts. very nice guy.
Old Nov 7, 2003 | 07:39 AM
MaScott's Avatar
Thanks, I just sent him a message.
Old Nov 7, 2003 | 08:02 AM
MaScott's Avatar
In the meantime...
1. searched www.partsvoice.com, found
22680-AD201 @ $488.19
2. searched www.nissan-auto-parts-dealer.com, found
22680AM600 @ $356.38
226806N201 @ $356.38 and
22680AD201 @ $356.38
nothing close to $75....
Old Nov 7, 2003 | 08:12 AM
eclane's Avatar
In the meantime...
those prices look like they are for the whole maf assembly, the black plastic tube the maf sit in and the maf sensor. You only need to replace the sensor and not the housing. If you call daveb he will just sell you the sensor and not the entire unit.
Old Nov 7, 2003 | 09:03 AM
MaScott's Avatar
Hmm.... I don't even know how to open that sensor to replace its element...
Old Nov 7, 2003 | 09:09 AM
PoLo's Avatar
2-Wheelin it...
ok, no more questions...until you at least talk to dave.
next word outta you mister and....
TallTom
57
Oct 14, 2025 05:16 PM
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
