Replace Side view mirror
Old Nov 17, 2003 | 11:24 AM
max 2k1's Avatar
We have all done it, - or know someone who has.
I smashed my passenger side view mirror on my 2k1 AE, pulling out of the garage. I broke the mirror, so much for 7 yrs of luck, and cracked the black coller around the mirror. The backside car color plastic piece popped off and is re-usable.
Can I just replace the mirror and coller?
- if so how?
Do I need to replace the whole unit?
- if so how?
any idea on the cost?
Mike
Old Nov 24, 2003 | 06:21 AM
max 2k1's Avatar
Hmm
No insight here?
Any idea what a reasonable cost for this part is then?
thanks
Mike
Old Nov 24, 2003 | 06:25 AM
Luquire's Avatar
i dont know but paradox has the mirrors that have the white blinkers on them and they might not cost as much as OEM. worth looking into
Old Nov 24, 2003 | 06:30 AM
max 2k1's Avatar
pointer?
Do you have a web pointer?
thanks
Old Nov 24, 2003 | 11:27 AM
max 2k1's Avatar
anyone else?
Anyone else have any ideas here?
anyone know of any vendors that sell a side view mirror product?
I was recently at the boston car show and the new lincoln ls
has a downward facing safety light that comes on and illuminates
the door and ground near your car when you use the remote.
seemed like a nice feature
for parking lots
mike
Old Nov 24, 2003 | 11:59 AM
bluemaxx's Avatar
Moderator GT-R
for parking lots
mike
I broke the left mirror at the base on my AE. Re-used the painted portion but the mirror with heat was about $260.00 from the dealer. I was able to replace it without removing the door panel but it would be better to remove the door panel, the wiring terminals connect behind it.
Old Nov 24, 2003 | 01:00 PM
Luquire's Avatar
check out custom maxima..they have the mercedes style but i dont know how good they are. And by the way i lied about paradox having them, sorry. I think they used to but custommaxima generally makes a quality product.
Old Nov 24, 2003 | 01:47 PM
01SE02SER's Avatar
Faster than a speeding bullet...
I believe the entire door mirror assembly comes as one part.
Looking at the Electronic Service Manual for the '01 Maxima, replacing a door mirror is a bit of pain since you have to remove the inside door trim/finisher. Here are the instructions for removal of the trim/finisher and then the mirror:
1. Remove door trim:
1A. Remove inside handle escutcheon.
1B. Remove screw securing pull handle, and then remove pull handle.
1C. Remove power window switch finisher, then disconnect the connectors.
1D. Remove mask securing front door finisher.
1E. Remove screw securing front door finisher.
1F. Remove clips securing front door finisher.
1G. Lift out front door finisher. Disconnect harness connectors.
2. Remove inner cover front corner of door.
3. Disconnect door mirror harness connector.
4. Remove door mirror harness clips.
5. Remove bolts securing door mirror assembly.
On my old Civic, a replacement door mirror ran me somthing like $100, so I would think $80 to $120 would be something to expect. Check with DaveB from this site.
Good luck.
Peace.
Old Nov 24, 2003 | 06:00 PM
Triple8Sol's Avatar
I miss the .org!
Custommaxima sucks. Also, what they are selling is only a plastic mirror cover w/LED that is taped onto the front of your stock mirror.
JRod28
Feb 4, 2016 11:07 AM
Huttig2009
Sep 25, 2015 03:31 PM
rtirbany
Sep 8, 2015 11:46 AM
Maxilano
Aug 31, 2015 07:33 PM
BobMax
Aug 19, 2015 04:39 PM
