How many have changed their in cabin filter?
Old Nov 23, 2003 | 01:55 PM
Zero Deuce SE's Avatar
Nissan recommends replacing it every 15k miles or annually. I have had my car for 22 months now and almost 22k miles on it. I have not changed it yet. I believe that if you don't drive in dusty places, it should last longer than they say.
http://www.courtesyparts.com/Merchan...de=B7200-00005
Old Nov 23, 2003 | 02:07 PM
NYC TAR's Avatar
the ones that came with the car is washable, just dip in sopy water and rince and dry. it should say in the glove box. no need to replace.
Old Nov 23, 2003 | 02:18 PM
All righty then. Thanks mate.
Old Nov 23, 2003 | 02:27 PM
Nathan's Avatar
Yup, I too just washed the filter in soapy water and it came out pretty clean. I dont drive in dusty areas either, however the filter was very dirty, I was really surprised.
Compton's Avatar
Can those of those that don't have them just buy one and drop it in?
Old Nov 23, 2003 | 02:32 PM
SoonerFan's Avatar
Cletus
nope. there will not be a housing for one. my 2000 doesnt have one.
Old Nov 23, 2003 | 02:52 PM
SE01Maxima's Avatar
I changed mine when i bought the car back in september. the car had 50K on it, and i think the filter did too..the a/c stunk really bad, kind of a moldy smell. Replaced the filter and that solved the stink.
Old Nov 23, 2003 | 03:03 PM
serin's Avatar
i didn't buy my car with it, but i popped one in later. there's a housing for it behind my glove compartment.
Old Nov 23, 2003 | 03:04 PM
You will need to check behind your glove box to see if you have the slot for a filter.
Old Nov 23, 2003 | 03:47 PM
SoonerFan's Avatar
Cletus
it was an option in at least 2000. mine does not have a housing.
Old Nov 23, 2003 | 05:14 PM
Maximam's Avatar
Changed mine @ 80k miles.
Old Nov 23, 2003 | 05:19 PM
irish44j's Avatar
retired moderator
Mine has the slot but no filter....I think maybe the slots were on the 2k SE but maybe not other models...you have a GLE right? Just a theory....
Old Nov 23, 2003 | 06:13 PM
SoonerFan's Avatar
Cletus
but you would think if anything the GLE (high end model) would have it.
again it was an option. maybe the previous owner got that option on yours
Old Nov 23, 2003 | 06:21 PM
Maxxed03's Avatar
I changed mine because I was bored and had extra money to give to Nissan
Old Nov 23, 2003 | 06:23 PM
From what I read in the 2k brochure, the in-cabin filter is listed as an additional accessory along with air bag anti-theft bolt, ashtray kit, battery warmer, cellular phone (in dash), chrome exhaust finisher, cigarette lighter element, engine block heater, gold badging, trunk convience net, trunk organizer, wheel cover and wheel locks.
Old Nov 23, 2003 | 07:18 PM
cabernet's Avatar
I have a stock 2K GXE. It didn't come with a filter but you can add one. I did. Every 2K has the slot and housing for it. Also, not every one is washable. Many of the OEM filters are paper and not washable.
Old Nov 23, 2003 | 07:24 PM
KLOOGY's Avatar
L33t BMW Drivah
I changed a few weeks ago....it was dirtier than all heck...I have about 53k miles....
Old Nov 24, 2003 | 12:38 AM
cwerdna's Avatar
I washed mine a few months back. It came out pretty clean (but not as clean as new).
Old Nov 24, 2003 | 04:10 AM
pruizgarcia's Avatar
Planning to change or clean it before next summer.
Pedro
Old Nov 24, 2003 | 06:13 AM
nhokt's Avatar
My 2000 GLE has never had one installed but I saw where it goes... you just need to pop out the plastic cap that covers the hole (our 2002 supercharged Xterra has one that I've changed so I knew what I was looking for). I'll probably put one in at the end of the winter.
Old Nov 24, 2003 | 06:26 AM
max 2k1's Avatar
Instructions to do so
I remember seeing somwhere the instructions to do this - taking
apart the glovebox etc to get at the filter.
With search not working, can someone either
1) write up the procedure - I remember there being a warning about
the passenger side airbag issue.
2) or point me/us to the procedure thread
thanks!
Mike
Old Nov 24, 2003 | 07:54 AM
cabernet's Avatar
thanks!
Mike
Courtesy Nissan has instructions - they also came with my filter. courtesyparts.com or
filterinstallation
It was a little confusing getting past step 1. The 2K GXE doesn't have a lower glove box finisher so I was looking everywhere for it. About 30-40 minutes work the first time. Would take about 15 minutes the second time.
Old Nov 24, 2003 | 09:46 AM
NYCe MaXiMa's Avatar
my 2000 has no options, it's a bare bones 2k
i probably don't have it then, right?
Old Nov 24, 2003 | 09:50 AM
You may not have the actual filter but should be able to buy and install one. There is probably a plate where your filter would go. You will have to remove your glove box to inspect it.http://www.courtesyparts.com/instruc...binfilter.html
Old Nov 24, 2003 | 10:39 AM
2002 Maxima SE's Avatar
Are you sure that was dirt? Some of them come with carbon imbedded in the media.
Old Nov 24, 2003 | 03:46 PM
I just took mine out tonight. I held it up next to an old engine MAF filter and they are almost exactly the same. The engine air filter has a rubber gasket around it, that can be removed. The inside air filter has less width than the engine air filter, however the length is the same.
I wonder if there is an engine filter out there for another application (Ford, Toyota, etc) that you could get at pepboys to replace your inside air filter?
Mine had 4 numbers on it:
27274 4Y110
3S440 70110
What do those mean? There were no other part numbers (like the carbon one on courtesy's site)?
Old Nov 24, 2003 | 04:23 PM
27274 4Y110
3S440 70110
I also took mine out today. It has the same numbers as yours has. I don't what they mean except for a part number they used when they were making them at some time. I cleaned mine with Dawn and warm water. It had a lot of pine seeds in the pleats. There was some dirt that did not come out. I dried it under a fan on high speed and put it back in the car.
Old Nov 24, 2003 | 04:30 PM
NewbieMaxOwner's Avatar
I am trying to install my mine now. I am also unable to locate the lower glove box finisher in step 1. I have a 2k1 SE. Does my car have this lower finisher?
Old Nov 24, 2003 | 04:38 PM
The best way to tell is to look underneath your glovebox. If you see a screw on either side of the bottom like my 2k2, you don't have the finisher. There are 4 screws in the top and 2 in the bottom on the 2k2. There are also two clips at the top that hold it in place. You have to remove the ABS connector clip from the holes in the back of the glovebox and disconnect the light harness plug.
Old Nov 24, 2003 | 06:08 PM
Triple8Sol's Avatar
I miss the .org!
The Courtesy Nissan instructions call it an A/C filter...is that true? I thought it filtered all air hot/cold?
Old Nov 24, 2003 | 06:27 PM
There is only 1 in-cabin filter that I know of in the newer Max. Even though they may refer to it as the A/C filter, it's the same animal.
Old Nov 24, 2003 | 07:42 PM
Triple8Sol's Avatar
I miss the .org!
I understand that. What I'm asking is "what does the filter...filter?" Only A/C or the hot too...
Old Nov 25, 2003 | 04:59 AM
It filters the air coming from the outside of the car for the entire ventilation system.
Old Nov 25, 2003 | 05:46 AM
Me neither and I have a 2002. Why are we missing this finisher that does not seem to be on 2000 - 2003?
Old Nov 25, 2003 | 05:58 AM
I don't know. As long as the car works fine, I don't miss it one bit.
Old Nov 25, 2003 | 11:39 AM
frankieduxAE's Avatar
hmm learn something new everyday. did not know that you can change the air filter for the a/c.
i love maxima.org
- frank
Old Nov 25, 2003 | 05:12 PM
bigdo26's Avatar
I will never again go over a year without washing mine. it was nasty when I removed it the other week. Very, very dirty.
Old Nov 27, 2003 | 05:38 PM
Edward Lee's Avatar
In-cabin microfilter
My 2k SE didn't come with an in-cabin microfilter so I went to the dealer, purchased one and dropped it right in. Your car does have a place behind the glove box for the filter. Go down and get yourself a filter, you deserve it.
Old Nov 27, 2003 | 08:03 PM
fishhouse's Avatar
like $50 right? i'll pass!
my $1 christmas tree freshner on the rear view works great! (jk)
Old Nov 27, 2003 | 10:08 PM
MaxJag's Avatar
I changed mine at 47K. Easy to do. All you need is a screwdriver.
homewrecker
Sep 23, 2015 03:41 AM
JoshG
51
Sep 21, 2015 10:41 PM
iamute
Sep 20, 2015 05:22 PM
bumpypickle
Sep 20, 2015 08:22 AM
thenewguyy
Sep 12, 2015 11:12 AM
