HowTO: New GAB design
Old Sep 28, 2009 | 08:06 AM
  #81
choiiiiiiiiiii's Avatar
wow at you resurrecting this....
Old Sep 28, 2009 | 11:52 AM
  #82
zidave's Avatar
Whatever...**** on both of you
Old Oct 19, 2009 | 04:37 PM
  #83
tkedch's Avatar
Just wondering if anyone has any knowledge as to what effect on the car it would have to remove the sensor on the side of the intake snorkle?
Old Oct 19, 2009 | 04:43 PM
  #84
bigpopaj369's Avatar
its an air intake sensor (forget the real name) but just take it out of the scoop carefully and zip tie it to the battery tie down. i take it ur guna install an intake?
Old Oct 19, 2009 | 04:47 PM
  #85
tkedch's Avatar
Originally Posted by bigpopaj369
its an air intake sensor (forget the real name) but just take it out of the scoop carefully and zip tie it to the battery tie down. ur lucky i answered u cuz ud normally get flammed for bumping million year old threads, itake it ur guna install an intake?
I assume the ECU uses it to calibrate throttle and things like that. So even if I tie it to somewhere in the engine, it wouldn't do me any good would it? I am just thinking about this because I have some ideas of GAB, but dunno if that sensor is crucial to be part of it.
Old Oct 19, 2009 | 04:52 PM
  #86
if ur removin the snorkel the best place to put it is zip tied to the battery tie down that way it gets a decent reading of the air that ur car will be sucking in it will be fine there
Old Oct 19, 2009 | 04:55 PM
  #87
tkedch's Avatar
I am actually thinking to use the existing intake box minus the snorkel, then extend it to just behind the bumper. Sounds like an idea or someone else has already tried it?
Old Oct 19, 2009 | 04:59 PM
  #88
thats how mine is ran right now i broke my maf adapter so i just did the GAB with a coat hanger until my new adapter comes in
Old Oct 20, 2009 | 09:22 AM
  #89
tkedch's Avatar
After reading some reviews on what ppl use for their intake, either GAB , CAI, or short ram, I just have the feeling that maxima does not benefit as much from those intakes as much as other cars. sure, you get some top end power at the expense of torque and responsiveness. Good thing, I did not spend money on those expensive intakes yet. Maybe GAB is the way to go hahahaha
Old Oct 20, 2009 | 10:05 AM
  #90
honestly if u dont care about looks then yes, i usually run just a maf adapter and filter u can get them for like $20 on ebay the filter isnt that great but it works just fine
Old Oct 20, 2009 | 10:08 AM
  #91
tkedch's Avatar
would you care to elaborate what your setup is like? MAF adapter and filter? I just want to see what it looks like and maybe i'll do that same. hahahah
Thank you very much!
Old Oct 20, 2009 | 10:11 AM
  #92
Old Oct 20, 2009 | 10:12 AM
  #93
hope that helps bro
Old Oct 20, 2009 | 10:14 AM
  #94
tkedch's Avatar
hope that helps bro
WOw, I see, you basically took out all the tubings and housings before the MAF and hook up a filter to it. so essentially it's a shorter version of those short ram filters that they sell out there, am I correct?
Old Oct 20, 2009 | 10:18 AM
  #95
yep pretty much its clean and works great and best part very inexpensive! its really easy to install just get a filter and adapter from ebay or autozone and 4 nuts,bolts washers and remove all the stock airbox and take out the air sensor thingy and the other sensor and zip tie them out of the way. then upbolt the maf tube from the airbox connect the adapter to it and the fliter then ur done.
Old Oct 20, 2009 | 10:20 AM
  #96
tkedch's Avatar
So I am assuming you would have the same problem as short ram filters do where it feels sluggish at start up and on hot days right? Just want to know the pro and cons of that setup.
Old Oct 20, 2009 | 10:26 AM
  #97
basically any setup stock or custom is guna be affected by heat, as for the start up if ur talkin about like off the line then yes ur guna loose a tad bit of low end torque but honestly with these cars they already have alot of it so its not like ur noticing huge differences. mine has a nice whistle to it too at certain revs kinda sounds like a turbo it sounds really deep and throaty so its worth it if ur lookin for a little more top end and and alot of wooooop! lol
Old Oct 20, 2009 | 10:30 AM
  #98
tkedch's Avatar
After seeing your pic with your setup, I was like did you steal mine and pop a filter to it. hahahaha. Anyway, Do you have the MAF adapter part number? and I am assuming any cone filter will work right?
Old Oct 20, 2009 | 10:35 AM
  #99
unfortunitly i dont have the number but if u go on ebay they have it i havent seen one lately for the 2ks up so im guna just get the 95-99 one like this http://cgi.ebay.com/ebaymotors/ws/eB...tab%3DWatching and if u want to get the adapter at autozone just go to the section with all the intake parts they have the adapter for like 6 bucks n they have the same filter as the one i posted from ebay for 25 bucks.yes any filter will work as long as its the same as the adapter 3''.
Old Oct 20, 2009 | 11:12 AM
  #100
tkedch's Avatar
Why not use some pop charger filter? I thought those are better than those most other cone filters. assuming price is not a concern.
Old Oct 20, 2009 | 02:17 PM
  #101
i never really thought about it i guess, i just use the cheap spectre ones that come with it til i can afford to dump $40 bucks on the one i really want
Old Oct 21, 2009 | 06:51 AM
  #102
CDN2000SE's Avatar
To really get cold air moving wouldn't you have to relocate the battery? get it out of the way! I can't see how drilling 4 holes is going to increase volume and especially temp from that part of the engine bay?
Old Oct 22, 2009 | 09:46 AM
  #103
tkedch's Avatar
They didn't say GAB is meant to be cold air intake. Those holes would just increase the volume of air that's available to the engine when you rev high, it is in fact the same principle as WAI, or short ram intakes you can buy on the market. During high way speed, the air that intake draws from is still a bit higher than ambient. It's during the standing around on a hot day that it really affects the start up performance. To really get true CAI requires making a hole in your fender well to gain access to the "cleaner" air behind the bumper. But personally after reading what everyone had to say, there's just no real cover all bases intakes for 5th gen maxima. And that's just too bad.
Old Nov 9, 2009 | 10:24 PM
  #104
InfiniwhiptinitiII's Avatar
sooooooooo ive got an intake coming but not for a while and i am doing that tomorrow. only better with grease slash more enforcement and not a hanger but wicked thick wire or some bleep from the harware store. great write up!
Old Feb 3, 2010 | 06:07 PM
  #105
Z-Powered's Avatar
At the risk of sounding stupid, would duct tape work? All that's important is that the filter is properly sealed to the housing, right?
Old Feb 3, 2010 | 08:11 PM
  #106
nismopc's Avatar
Old Feb 3, 2010 | 08:42 PM
  #107
Scottwax's Avatar
That's Mr. Detail to you
I guess you can remove the hood and do something like this:
Old Feb 3, 2010 | 10:29 PM
  #108
CMax03's Avatar
Real Ghetto Action
This Mopar Lebaron should've just dropped in a 2.2 turbo 4, instead of the hard to mod 3 liter sohc Mitsubishi
Old Feb 3, 2010 | 11:32 PM
  #109
a33i30's Avatar
It might not work because you can't duct tape the bottom part of the filter. Hanger is MUCH easier.
Old Feb 4, 2010 | 02:14 PM
  #110
Z-Powered's Avatar
Ok, hanger it is then. I just thought using black duct tape would look less ghetto.
Edit: I did it with the hanger, and it works perfectly! Awesome write up.
Old Feb 4, 2010 | 04:53 PM
  #111
boost4age's Avatar
Would it possible for you to post some audio of it?
Old Feb 4, 2010 | 07:16 PM
  #112
Z-Powered's Avatar
No problem. The vid should be up on YouTube soon. I'll edit my post and add the link.
Video: http://www.youtube.com/watch?v=UTYhneOJE1s (most of the action is at 1:37, 3:55, and 5:12)
Old Feb 4, 2010 | 08:48 PM
  #113
boost4age's Avatar
hmm....just seems like the engine is louder. I also did the GAB but i drill 4 holes, i think the holes are better it kinda make a growl
Old Feb 4, 2010 | 10:39 PM
  #114
Z-Powered's Avatar
I might need to go back to stock...
I think I'll just save up for an intake. I heard the Berk one is good?
Old Feb 4, 2010 | 11:46 PM
  #115
a33i30's Avatar
Adds hp too, in one of the posts it was dyno'ed. Make sure the filter does'nt drag down tho, dirty air will mess up the MAF.
Old Mar 11, 2010 | 07:52 PM
  #116
Mynameismcgyver's Avatar
Im going to test this tomorrow. But along with the hangers I am going to apply a small bead of RTV sealant around my KN filter. This will help ensure the filter is properly sealed and held in place.
Old Sep 19, 2010 | 09:39 PM
  #117
maximav6p0w3r's Avatar
i tired the wire hanger and it just wouldnt work for me.. i got so frusterated.. cut the wire up and tried wedging a few pieces securing the filter but, i dont have a clue how to wedge a few pieces to the bottom portion of the filter.. any help?
James92SE
142
Jan 2, 2024 09:23 AM
Sep 27, 2015 08:37 AM
RWCreative
Sep 21, 2015 11:01 AM
QueensMAX
Sep 15, 2015 04:14 AM
