I just rewire my fog lights in 10 min....
Old Nov 30, 2003 | 11:06 AM
MaximaPolak's Avatar
....including opening of the "black box" where it is labeled "fog?".
This is the most GHETO setup. I didn't drill holes nor broke anything.
I used a knife and electrical tape because I had no wire strippers.....mmm strippers! LMAO. ANYWAY HERE ARE THE PICTURES!
Old Nov 30, 2003 | 02:22 PM
KLOOGY's Avatar
L33t BMW Drivah
What exactly did you do that only took 10 minutes ?
Old Nov 30, 2003 | 02:43 PM
02MaXiMa_GLE's Avatar
Yeah, please do share...
Looks like it's working just fine.
G
Old Nov 30, 2003 | 02:48 PM
RichK's Avatar
Took me 15, but I used solder and heatshrink tubing.
Old Nov 30, 2003 | 06:54 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
took me only 5 minutes to do it. Go in the box, Cut a wire, use a tap into another wire and tape it up.
If i did it again, the only time would be opening the fuse box.
Old Dec 1, 2003 | 07:26 AM
2k2MerlotSE's Avatar
JUVIN's ride
the write up in the how to's looks like it will take a lot longer than 10 mins. Did you follow the instructions or did you wing it yourself?
Old Dec 1, 2003 | 07:32 AM
Lumbee1's Avatar
It took longer than 10minutes. I raced through my fog light rewire and it still took me 28minutes. I timed it.
Lift hood, open box, find first wire, find second wire, cut, tap, reassemble.
Old Dec 1, 2003 | 07:57 AM
JUVIN's ride
does anyone have the 2k2 write up?
Old Dec 1, 2003 | 08:58 AM
When I did this, I had opened my box before, So i knew how to open it this time. I figured out a way to open it without taking the whole thing apart. Once you get the Clips open from the engine side you can open the box in HALF. It is made of 2 parts. It took me only 10 min to do this because it was so cold I needed to finish QUICK. I used a Box Cutter Knife not a Stripper. Taped it up at the end with Electrical tape. (No need to sodier. You only need to twist the wires tightly.)
BTW: I just ordered Piaa Extreme White Bulbs for the Fogs.
$20 each. 4150K close to our HID 4300K.
Old Dec 1, 2003 | 10:31 AM
TitaniuMax03's Avatar
ok...so which wires need to be spliced and wired together (colored description please) a quick write-up would be helpful..
Old Dec 1, 2003 | 10:41 AM
JustTry's Avatar
1. take off fuse box cover
2. undo clips holding the top half of the fuse box on
3. run a long wire out of box (there are vents on the bottom half of the box, you can slip it through, and it has to be long enough to reach the headlight)
4. (for 2k2-2k3) Cut the blue wire w/ silver dots a few inches from the relay (under the part that says FR fogs) and connect your NEW wire to it. (blue wire from relay connects to new wire)
5. Other end of new wire splices into (do not CUT) the green wire for the corner lights (that are right above the blinkers)
Done
I have a question. Noone seems to know how to have the fogs on w/ the high beams on, and was wondering if you could connect maybe a wire from the high beams to the same wire you put in there. (that connected the cornering lights and relay)?
Old Dec 1, 2003 | 11:02 AM
spirilis's Avatar
Still won't work.
The problem is that the foglight relay (switch-side) circuit GROUND passes through the high/lowbeam switch, and it only allows ground conductance in LOWBEAM mode.
The easy, but ghetto solution for this is to install your own switch between the foglight relay's ground wire and a real ground. This will become your new foglight switch. But that's ghetto, since you'll still have your foglight switch on the steering column arm.
I've yet to fully evaluate the layout to see if it's possible to tap a wire in the steering column, or if you have to disassemble the steering column and internally rewire the combination switch to get it working. Maybe I'll do it someday when I'm bored, or when it's warm out (i.e. this spring )
Old Dec 1, 2003 | 11:29 AM
JUVIN's ride
did you have put a higher amp fuse?
Old Dec 1, 2003 | 11:32 AM
bigdo26's Avatar
ya mine only took like 30 minutes and i had some breaks too... only problem now is that a foglight burnt out. probly unrelated, but I dunno. anyone else had a fog burn out? it was the drivers side fog
Old Dec 1, 2003 | 12:20 PM
jesse's Avatar
VTEC This!
took me like 30 min to do mine, but I bought a fuse and crap, did it right
Old Dec 1, 2003 | 04:22 PM
JUVIN's ride
what do u mean?
did you put a larger fuse in the fuse box?
Old Dec 1, 2003 | 07:10 PM
KL99SEA's Avatar
twisting wires together and saying thats all it needs ...............break out the glue, tape and string while your at it. Spend another 10 minutes and do it right, then you won't have crusty corrodded wires in 6 months. You should be ashamed to do that to a nice car.
Old Dec 1, 2003 | 09:09 PM
limsandy's Avatar
Okay, so I took off my fuse box cover and I took a picture which looks something like this:
http://images.cardomain.com/member_i...681_3_full.jpg
At this point, I can see the blue/silver dotted wire running through, but it's impossible to tap that wire into another because I have no room to work with. What's next?
~limsandy
Old Dec 1, 2003 | 11:11 PM
Eat Naaawwwzzzzz
lim, why dont you open the fuse box and work from underneath? Its much easier
Old Dec 2, 2003 | 10:59 AM
limsandy's Avatar
How???
~limsandy
Old Dec 2, 2003 | 11:57 AM
Originally Posted by limsandy
How???
~limsandy
didn't i already explain it? There are 3 tabs on the box from the engine side and 2 form the fender side--Those are the worst to get off.
Old Dec 2, 2003 | 02:30 PM
gsumax's Avatar
be aware of the ghetto setup! i did mine in like 10 mins too only with electrical tape, and a week later my fogs completely went out. I have NO idea whats wrong with them. (and yes ive checked all fuses and connections.)
Old Dec 2, 2003 | 06:03 PM
That sounds bad. Maybe tomorrow I will solder the wires so nothing will happen.
BTW: What guage wire did you use??? I Used a 12 Guage. (thick Mother Fuc*.)
Old Dec 2, 2003 | 06:36 PM
gsumax's Avatar
i dont even know,it was just some wiring sittin around my house, i think like 16, maybe 14
yeah i know, im a cheapass
Old Dec 4, 2003 | 09:37 AM
ok it took me an extra 3 minutes to solder the wiring in school....since you are complaining so much
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
