is droppin my car gonna mess up my suspension
Old Dec 7, 2003 | 01:33 PM
scopium
i have maxspeeds and tockicos on my car
my dad keeps tellin me to take them off cause its gonna mess up my suspension
is that true....
please inform me
Old Dec 7, 2003 | 01:58 PM
limsandy's Avatar
No.
~limsandy
Old Dec 7, 2003 | 02:00 PM
Maximus03SE's Avatar
is that true....
please inform me
Your struts/springs pretty much is your suspension. Not sure what's left to "mess up" ?
If you go lower than 1.5 inches you might need to get some adjustable camber plates for your front struts (to get and keep a good front end alignment).
Other than that, you're really not messin up anything.
Old Dec 7, 2003 | 02:10 PM
ch13f's Avatar
Does your dad have any mechanical background?... THe springs and struts are basically your whole suspension.. Being lowered can put some extra wear on a couple parts but nothing serious.. plus maxspeeds aren't very low and have a relativly soft spring rate. With maxspeeds you don't need to worry about camber, as already mentioned, just get an alignment when the springs settle and you'll be all set.
Old Dec 7, 2003 | 02:16 PM
ToYLeT902's Avatar
JET Speed Lab
Your dad is funny
Old Dec 7, 2003 | 02:24 PM
limsandy's Avatar
You dont need camber plates even when you drop your car with Tein springs (2.2 inches). Make sure you get aftermarket struts/shocks.
~limsandy
bigdo26's Avatar
All it could do is alter your tread wear if you dont adjust the camber of the wheels. If ya installed it right and made the necessary adjustments, there is absolutely nothing to worry about.
Old Dec 7, 2003 | 04:32 PM
defsquad222's Avatar
If you lower your car excessively, you will put pressure on parts that may not be able to handle it. I needed some parts to be replaced after two years because of the lack of travel on the shocks(struts)....as long as the springs dont drop the car more than 1.5-2 inches, I think you should be fine...make sure you keep your struts in good shape...if you drive with worn out struts, YOU WILL ruin your car....im not a mechanic, but this is from experience of tinkering with different heights on my max with different struts...thats all...
Old Dec 7, 2003 | 05:32 PM
2k3TitaniumSe's Avatar
L owering the car won't mess up th suspension at all!
Old Dec 7, 2003 | 06:08 PM
Ammi's Avatar
350 Detroit Muscle
Too much lowering will wear out parts faster.
Old Dec 7, 2003 | 06:49 PM
† ErV †
bushings
links
arms
bars
yeah sure springs and shocks are all there is (cough sarcasm cough)
it won't hurt anything unless you offroad it.
Old Dec 7, 2003 | 07:01 PM
Tac_M's Avatar
yes it will mess it all up man... first a drop, than nos and than some 20000 Jigawatt sound system.....
Old Dec 7, 2003 | 07:24 PM
Mick Max's Avatar
Wild at Hurt
Just take it kinda easy over RR tracks etc and you'll be fine.
Old Dec 8, 2003 | 08:18 AM
Galo's Avatar
Maxima Pilot
I think my son would prefer his dad to your dad!
Old Dec 8, 2003 | 08:24 AM
MannyNJ2k2max's Avatar
I'm iffy about dropping my max cause I couldn't enjoy driving my car if it was stiffer-
Question: can the lowering springs be added to just the front ? (keep stock in rear) My **** droops down lower now w/ my sound system- so the front gap bothers me
Old Dec 8, 2003 | 08:33 AM
Black2000maxima's Avatar
the only foreseable problem I see/have is,
lowered car + shietty NYC pothole streets=rattles galore-especially dashboard
Old Dec 8, 2003 | 08:41 AM
scopium
my ride is smooth most of the times.. just when i hit potholes and dents in the road.. my car feels like its bout to explode
fishhouse's Avatar
you've got to buy a set of 4 springs anyways. even on stock max's (without a sound system in the rear like yours) the front has a larger wheel gap. that is why all brands of front springs drop MORE that the rear.
if you are going to do it...just install both. the new lowing springs will drop more in the front - to help even out your drop.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Quickgtp
Apr 13, 2017 03:30 PM
Chef N
Sep 22, 2015 11:20 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
