What kind of battery is in YOUR Max? (Optima, Die Hard, etc...?)
Old Dec 13, 2003 | 05:41 PM
turbomolar's Avatar
Just wondering...
Does anyone happen to have an Optima Red Top battery in their
02 Maxima? If so, which one did you use, and was there any problem
with "shoe-horning" it in there?
Thanks for the input!
Old Dec 13, 2003 | 05:43 PM
92 SE-R 02 SE
when mine goes, im going to get the yellow top.
Old Dec 13, 2003 | 05:48 PM
† ErV †
same here. i am sure my oem one will go soon enough..
Old Dec 13, 2003 | 06:10 PM
Maxman2000's Avatar
My dad's is still running on the same one from when we bought the car surprisingly.
Old Dec 13, 2003 | 06:14 PM
KLOOGY's Avatar
L33t BMW Drivah
Yellowtop Here !
Old Dec 13, 2003 | 06:36 PM
2k3TitaniumSe's Avatar
whats the ndifference with the optima yellow top and die hard gold? Everyone's making a big deal about the optima yellow top.
Old Dec 13, 2003 | 07:59 PM
FanaticMadMax's Avatar
None of those, still with my original OEM battery. Hasn't given any trouble with 27k miles logged on it.
Old Dec 13, 2003 | 08:02 PM
KLOOGY's Avatar
L33t BMW Drivah
Youre not running 2- 800 Watt Rockford Fosgate amps.....
Old Dec 13, 2003 | 08:42 PM
MrGone's Avatar
Dads 5th gen: Interstate (Dont know if thats factory or not)
My 3rd gen: my trusty Kirkland signature big-un. You'll never take it from me
Old Dec 13, 2003 | 10:00 PM
HitManSE's Avatar
I got the optima yellow top... ...two of them
Old Dec 13, 2003 | 10:59 PM
turbomolar's Avatar
Does anyone know what the difference is between the Optima Yellow and Red tops? Looks like the Red tops are a bit more expensive than the Yellow. Why is that?
ps
For you Yellow toppers out there...
do you remember what size you got?
(35? 24f?)
Old Dec 13, 2003 | 11:26 PM
HitManSE's Avatar
Yellow top is a deep cycle battery. The yellow top is more expensive from what I remember. Deep cycle means its gonna take a little while for it to drain. Basically I can park my car & bump in a parking lot for a while & still be alright while normal batteries will drain after a short while.
The model # is 34 last I checked. The only weird thing is the posts are reveresed. You can obviously work your way around that.
Old Dec 13, 2003 | 11:37 PM
MaxVader's Avatar
Yellow Top Here
Old Dec 13, 2003 | 11:51 PM
KLOOGY's Avatar
L33t BMW Drivah
I can bump mine for almost an hour at full blast, and when I drain it, just give it 10 minutes and it fires itself back up ! I run one set of posts for the car, and the other set goes to amps...
I wish I had two like you !
Old Dec 14, 2003 | 12:01 AM
cyclecrazy55's Avatar
Optima Red Top
I have 80K on my 2000 Maxima and decided the old battery needed to be retired. I've done my share of leaving the lights on overnight. Surprisingly the stock battery still ran pretty well but I saw the Optima red top was a good performer. I had to buy a 5 inch battery terminal extender and hook it up to the positve post. The stock Max terminal has this housing thats forms a right angle that won't fit easily on the Red top. This was an easy fix and the Optima runs Beautiful. Do the Red top. You won't regret it.
Originally Posted by turbomolar
Just wondering...
Old Dec 14, 2003 | 12:06 AM
HitManSE's Avatar
If you have a system or are planning on it YT is the best choice. If you want just a basic upgrade then RT. Plain & simple.
Old Dec 14, 2003 | 12:11 AM
KLOOGY's Avatar
L33t BMW Drivah
Like Hitman said, if you dont ever want to worry about a dead battery , since you have no system.... get a yellowtop....its worth the peace of mind. You can leave all the lights on and walk away for a week.... and it still wont be completely dead !
Old Dec 14, 2003 | 12:18 AM
asu174's Avatar
Clay Aiken has fancy genitals
Night and day......
Old Dec 14, 2003 | 01:21 AM
MyownNismo's Avatar
Future Camaro SS owner
I am getting a yellow top once I get my 1000 watt amp. I might as well get a cap too.
Old Dec 14, 2003 | 01:50 AM
HitManSE's Avatar
Ahh, screw the cap. I had two...then I returned them and got another YT for $10less more bang for the buck IMO. If you dont care about weight though.
Old Dec 14, 2003 | 04:37 AM
Bluesbrekr's Avatar
Doctorate in Detailing
Just wondering...
with "shoe-horning" it in there?Thanks for the input!
I got the smaller sized Red Top. Still plenty of power and CCA and the posts are closer to the edge so I didn't have to bend the + connector or add an extender.
Old Dec 14, 2003 | 05:41 PM
Jackboot's Avatar
OT
I really love how the injen looks
Old Dec 14, 2003 | 07:56 PM
00MaxSE's Avatar
Pointy Elbows
48K and I'm still on the OEM battery.
Old Dec 14, 2003 | 07:59 PM
shonufmax's Avatar
Optima Yellow top
I purchesed the yellow top battery and put it in, from the jump I noticed:
1. It's not the same height as my stock battery, so the stock battery tiedowns were no good
2. The post was to far from the edge, so my positive connection would have to be modified, by either cutting the wires and using one of the aftermarket terminals for car audio or bend that stupid stock L bracket some kind of way to make it fit ...Does any one know off hand what that stupid fuse is for anyway on the positive bracket?
3. I diddn't want to deal with all that! So after all that I bought A= Energizer form Pep Boys it works
Old Dec 14, 2003 | 08:03 PM
NYC2SD's Avatar
I had my stock battery replaced under warranty 2 months after I bought the car. The b&tch was leaking acid all over the place.
HNDA ETR's Avatar
Still Here... IM me for more..
Die Hard Gold!
Old Dec 14, 2003 | 08:16 PM
MyownNismo's Avatar
I had a yellow top with a cap on my last system with my 2 400 watt amps and had no problems. I am sure Kloogy isn't have a problem.
Old Dec 14, 2003 | 09:06 PM
twotone's Avatar
isn't yellow top a replacment for stereo batteries?
I'll probably go with red top...
Old Dec 14, 2003 | 09:59 PM
scmaxima2k's Avatar
Im using a yellow top too.
-Steve
Old Dec 18, 2003 | 09:05 PM
00MaxSE's Avatar
Pointy Elbows
Bluesbrekr,
what's the part # of the Red top that you have in your car? The battery in my truck just died, so I'm gonna buy an Optima for the max and put the OEM battery from my max into the truck.
Old Dec 19, 2003 | 08:57 AM
woreyah's Avatar
I'm runnin' RF bd1000 at 2ohms and 851x at 4ohms, 1 cap on OEM battery and no blinking lights(except the interior).
Old Dec 19, 2003 | 10:15 AM
frencjas's Avatar
OEM battery, and 75K on the odometer.
sctludwig
Sep 1, 2022 01:32 PM
The Frye
Sep 2, 2021 11:03 AM
captchaos
Mar 15, 2016 12:18 PM
markevans999
Sep 10, 2015 04:29 PM
MaxLife17
Sep 8, 2015 02:36 PM
