02 Fuel Filter
Old Dec 24, 2003 | 08:32 AM
rossg's Avatar
02 Fuel Filter
Can anybody tell me where the fuel filter is on a 02 SE ??? I understand it may be in the gas tank- if so, how do you access it and to anyone who has changed theirs, how much of a pain is it ??
thanks-
Old Dec 24, 2003 | 08:38 AM
Y2KSESteve's Avatar
You access it by removing the back seat. The filter isn't a pain to change, but does take time.
Old Dec 24, 2003 | 09:00 AM
jonbth's Avatar
According to Nissan, it doesn't have to be changed on a regular basis because of it's location. It's inside the gas tank.
Old Dec 24, 2003 | 09:19 AM
rossg's Avatar
Got it- thanks guys !
Y2KSESteve's Avatar
That would refer to it being "maintenance free". Nothing on cars is maintenance free.
Old Dec 24, 2003 | 08:30 PM
trey
Wait can the fuel filter even be changed by us?
Steve said that you have to remove the back seat, another person says its in the fuel tank. Why would u remove the back seat to get to the fuel filter in the gas tank?
Old Dec 24, 2003 | 09:05 PM
Fezzik's Avatar
When you remove the back seat you'll see an access plate that leads to the fuel tank/fuel filter
Old Dec 25, 2003 | 10:42 PM
Y2KSESteve's Avatar
What he said, and yes you can change the fuel filter. A number of us have on the board.
Old Dec 26, 2003 | 05:28 AM
Zero Deuce SE's Avatar
You only need to remove the rear seat bottom, not the entire seat. It takes a minute or two to remove and you don't need any tools besides your hands.
Old Dec 26, 2003 | 06:47 AM
spirilis's Avatar
Any special tools required for fuel filter replacement, besides the typical socket/ratchet set and screwdrivers?
(i.e. do you need a special punch tool to put the new seal on after the fuel pump's reinstalled?)
Old Dec 26, 2003 | 07:35 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
No...simple everyday tools will suffice.
Old Dec 26, 2003 | 09:42 AM
Colonel's Avatar
Old Fuddy Duddy
A pair (or two) of thin long nosed "needle nosed" pliers might be handy. Be careful once you have the fuel assembly out, you have to disassemble it to get the fuel filter out. Make sure to be careful not to break the quick disconnects on the sender assembly as one member found out.
Go slow, be patient...its not hard. Hit me up here if you need more help. I know this inside and out.
Old Dec 26, 2003 | 12:28 PM
maximalex's Avatar
Posted by jonbth - 12-24-2003 at 05:00 PM
Forget that the manual says. It's a filter like any other filter (that gets dirty, clogged, worn out) and it needs to be changed periodically. Sounds like a PITA to change ours but should be done.
Old Dec 26, 2003 | 04:57 PM
trey
Sorry if this has been asked before but in your guys opinion, how often should it be changed?
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
Justin Kroll
Oct 1, 2015 07:03 PM
