5th gen remote start...
Old Jan 5, 2004 | 08:20 PM
irish44j's Avatar
retired moderator
Anyone know if there is a remote starter available for a 2k Max with 5speed (stick shift)? I suppose it might be difficult due to the chip in the key and all that, and also on a stick shift....anyone know anything?
Old Jan 5, 2004 | 08:30 PM
futemv's Avatar
The chip in the key is routinely bypassed with the 555U bypass module from DEI (company that makes viper). And that module works with any remote start system if you hook it up right. As far as the stick shift, I think it's illegal to hook up a remote start to that, but there's definitely ways to do it and you can find an installer thats willing to do it fairly easily.
Old Jan 5, 2004 | 08:34 PM
Superman's Avatar
so if the chip in the key is bypassed by the module, does that mean that i can buy a blank key and have it cut and it'll work without being programmed?
Old Jan 5, 2004 | 08:38 PM
futemv's Avatar
If you hook the module up right, then no. The circuit containing the bypass is only activated when the system gets the remote start command. At all other times, the system needs a signal from the ignition key as usual. If you want to save the cash from programming the key, you could hook up the bypass to always be active, but then of course you're getting rid of the security of the chip system.
Old Jan 5, 2004 | 10:35 PM
gtbigup's Avatar
You may have a problem with the stick shift because most installers don't want the liability of you making the mistake and leaving the car in gear the try to start it, and run over someone. It can be done by bypassing the clutch but you'll have to find a friend to do it or figure how to do it yourself.
Old Jan 6, 2004 | 03:16 AM
limsandy's Avatar
There is someone who have manual tranny and remote start at the same time. Don installed most of the parts, but the last step has to be done by the owner, I think. I don't remember since it was a long time ago.
~limsandy
Old Jan 6, 2004 | 06:15 AM
Manaz101's Avatar
A friend of mine has the remote start on his prelude and it's a stick. I forget who installed it (here in Orlando) and which alarm he got, but it can be done with no big problems.
Old Jan 6, 2004 | 06:20 AM
PAPA SMURF
remote start can easily be added to a car with stick, but anyone with half a brain that doesn't want to risk losing their business will do it on the "downlow" and won't give u a receipt and will deny their responsbility profusely if ever questioned
Old Jan 6, 2004 | 07:10 AM
MannyNJ2k2max's Avatar
~limsandy
I'm not sure, but I think Guzo has that done...
Old Jan 6, 2004 | 07:25 AM
Luquire's Avatar
I have a 2001 standard tranny and i did it. You just hook up to the neutral ground safety switch. This is a green with white stripe wire found on the floor board on the passenger side wiring harness.
Old Jan 6, 2004 | 07:33 AM
Max6spd's Avatar
Almost any add on remote start should work on the max but you need to give up one of your keys (valet) permanently to be enclosed in the bypass module. As for the stick shift, I'm not sure on the 2k's but on the 2k2's there is gear sense wire on the ECM that can be used by the RS unit in conjunction with the clutch bypass that detects if tranny is in gear or in neutral. Depends if your installer is willing to make the effort.
Old Jan 6, 2004 | 07:42 AM
turbomolar's Avatar
Check out
www.compustar.org
I think it might have the longest range of any remote starters
out there because it uses 2.4ghz instead of 900mhz or radio frequencies.
Anyhoo...works great with my 02 Maxima SE.
Old Jan 6, 2004 | 08:37 AM
myktek's Avatar
i have the compustar alarm....and what we did was we wrapeed the valet key w/ a copper wire and then ran it inside the column and wrapped the keyhole on the inside of the column, so it transmitted the signal from the chip to the wire and tricked the computer that the key was inside the keyhole.... that worked for me....
MAXSE5SPD
Sep 17, 2022 04:00 AM
flu2000
Sep 14, 2015 12:34 PM
Violator
Sep 9, 2015 10:14 AM
intimidator
Sep 5, 2015 07:23 PM
Lowered_a33
Sep 1, 2015 07:49 PM
