coilover noise fixed
Old Jan 7, 2004 | 08:59 PM
chris'smax's Avatar
I finally got the damn coilovers fixed. After some piddling around I finally found the problem was a broken strut bearing. This is what was causing all the popping noise. After fixing it i took my car for a spin and i must say these things ride very quiet and pretty smooth for coilovers. I'll post some new lowered pics this weekend
Old Jan 7, 2004 | 09:06 PM
Cubanato's Avatar
Joo wanna play??......ok we go to war
GooD stuff man
now if i could only figure out all the little noises everywhere throught the Max
(maybe one day)
-J
Old Jan 7, 2004 | 09:10 PM
chris'smax's Avatar
Originally Posted by 2k2whitemaxi
GooD stuff man
(maybe one day)
-J
That would be a task that could be compared to climbing mount everest
Y2KSESteve's Avatar
Glad you got it fixed.
Old Jan 7, 2004 | 11:48 PM
FanaticMadMax's Avatar
What exacty are coilover, I have not heard of that before. Did you had it fixed by a mechanic or yourself?
Old Jan 8, 2004 | 05:59 AM
BEJAY1's Avatar
Conecarver
I found the same problem with one of my bearings when I installed my Cattman's. Thing was shredded to bits. My mounts may be worn too causing some squeakage still...
chris'smax's Avatar
True coilovers are a spring strut combo where you can adjust the ride height
Old Jan 8, 2004 | 06:04 AM
PoLo's Avatar
2-Wheelin it...
ah!!!. so it WAS the strut bearing. don't wanna take credit, but didn't i tell you that stupid POS piece may have been the cause to all this?!?! you'd think that of all the pieces, they'd avoid making things of such cheap quality, especially in your suspension.
Old Jan 8, 2004 | 06:12 AM
chris'smax's Avatar
no sh***, all i got to say is you da man
Old Jan 8, 2004 | 08:25 PM
RichSpidizzy's Avatar
These were the Tosers from ebay for like $500 right? You got such a friggin deal
Old Jan 9, 2004 | 08:59 AM
chris'smax's Avatar
No lie man I really lucked out on these, I would highly recomend these to anyone who is serious about getting coilovers
Old Jan 9, 2004 | 01:23 PM
HKMax's Avatar
What do these strut bearings look like? And under what circumstances did you hear the noise?
I am wondering because I currently have AGX and H&R combo with 18" wheels. Whenever I go over a slight bump I hear thumping noise from front. I am not sure if this has anything to do with bearings. And these AGX's are modified from 4th gen (not Cattman modified) to fit 5th gen.
Old Jan 9, 2004 | 07:44 PM
chris'smax's Avatar
i noticed it after every time i turned my wheel my spring woulding make a popping noise and was not turning smoothly. What you described is the same sound as my old setup made(progress/stock struts).
Old Jan 9, 2004 | 07:50 PM
Ammi's Avatar
350 Detroit Muscle
I hear thumping noise when I go over potholes but not when I go over bumps.
Old Jan 9, 2004 | 08:23 PM
HKMax's Avatar
Yea, that's actually what I meant. You get that noise also?
Old Jan 9, 2004 | 08:33 PM
HKMax's Avatar
Is there any remedy for this? Is my AGX set to soft or shot? I am thinking maybe it is set too soft because it sounds like the wheel assembly is sling shot to the ground when going over bump and potholes at moderate speed (~40mph) and the tires are slapping the road.... Any ideas?
Old Jan 9, 2004 | 08:48 PM
Ammi's Avatar
350 Detroit Muscle
Yeap.........
Old Jan 10, 2004 | 09:44 AM
HKMax's Avatar
Humty bumpy
NewMax03
Oct 29, 2015 07:44 PM
05RLS2
Sep 27, 2015 09:24 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
pears
Sep 18, 2015 05:25 AM
thenewguyy
Sep 12, 2015 11:12 AM
