2000 owners with a UDP
Old Jan 11, 2004 | 02:14 AM
thomasd cook's Avatar
Which belt is the rear pulley. I have the front belt and need to know what the rear belt is. Also is there anything else needed for UDP install besides UDP, Belts, Tools and motor oil?
Old Jan 11, 2004 | 09:19 AM
doublea's Avatar
You can find the belt number www.custommaxima.com to save you from searching here it is:
Alternator and A/C : Gates K060408 or K060410
Power steering : Gates K040300 ( 300 represent 300mm )
Just so you know I have the Motor Storm under driven Pulley, but since I dont have the belt in hand and the pulley is not install, I cant tell you for shure but I have 2 differents source who gave me those belt number, it should cost around 13-15$ each.
Hope it help.
Cheers
AA
Old Jan 11, 2004 | 10:59 AM
bsetiawan's Avatar
You can actually use the stock belt for the power steering. The recommended belts by Custommaxima and UR are both too short.
Old Jan 11, 2004 | 11:54 AM
Does the power steering belt go on the drive to the rear of the UDP? I have 1 belt and need to figure what the other belt is so I can have everything I need to install this. Also is there anything else that's needed for install. Will I need a pulley puller or will it just slide off when I remove the bolt holding it on. trying to get everything straight before i attempt this install.
mclasser
22
Nov 12, 2020 01:58 PM
TKHanson
Nov 24, 2018 01:39 AM
D Mason
Jun 21, 2016 04:43 AM
bernyp
Oct 2, 2015 10:10 AM
Need help
23
Oct 2, 2015 08:56 AM
