where is the fuel filter?
Old Jan 19, 2004 | 11:58 AM
fredflypogger's Avatar
hi
i want to change my fuel filter but can't seem to locate it. also what type of transmission fluid is used in a 2000 maxima. sorry for the stupid questions but i don't have a service or owners manual.plan to get one sooon
thanks
todd
Old Jan 19, 2004 | 12:26 PM
Colonel's Avatar
Old Fuddy Duddy
Originally Posted by fredflypogger
hi
thanks
todd
Fuel filter is in the gas tank. Long story short you have to pull back seat, and access panel to get at assembly to replace. Not hard, but will take you about 45 mins to 1.5 hours. I have done it.
Auto tranny or Manual?
Old Jan 19, 2004 | 01:59 PM
NYC TAR's Avatar
there you go
http://forums.maxima.org/showthread.php?t=276627
Old Jan 19, 2004 | 04:06 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
hi
thanks
todd
for tranny fluid, use anything comptaible to mercon/dexon 3. nissan will suggest using their brand, Dmatic or something close to that. i use mobil 1 atf and its compatible.
Old Jan 19, 2004 | 07:01 PM
ok, i will check that access panel. the car is an automatic. i was told to use dexron 3. thanks to all that replied
todd cerami
Old Jan 19, 2004 | 07:08 PM
spirilis's Avatar
fredflypogger: Check the thread posted above. I authored that thread. Please take note that the pics of the inside of the fuel filter housing will look a little different, as you will have 2 hoses instead of just 1... mine was like that because I ****ed it up and had to rig it to make it work until I get new parts (which, incidentally, I got today!)
Those pics will guide you, though, especially the part about removing the fuel pump housing.
If you want my opinion, I'd take it to the dealer to have all this work done. It's not worth having your car out of commission (or rigging your fuel pump assembly) if you make a mistake and break something. Not worth it at ALL.
Old Jan 19, 2004 | 07:35 PM
trey
How often should the fuel filter be changed if at all?
Old Jan 19, 2004 | 10:57 PM
thomasd cook's Avatar
How much do the filters run?
Old Jan 20, 2004 | 04:18 AM
spirilis's Avatar
After 50K miles, my 2K saw a significant difference. I'm planning for every 50K miles. Nissan claims this is a "non-maintenance item".
Fuel filter + new O-ring runs around $22 shipped from DAVEB at South Point Nissan.
I think the fuel filter itself is around $14, O-ring is $5. The O-ring should be replaced every time... it's an O-ring which seals between the fuel pump housing and the fuel tank at the top.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
Justin Kroll
Oct 1, 2015 07:03 PM
