30,000-mile service recommendation
Old Jan 20, 2004 | 09:32 AM
muzikool's Avatar
My Maxima just recently passed the 30k mark, and Nissan's website gives me the following service recommendation:
30000 Replace Engine oil Oil and air filters Engine coolant In-cabin microfilter (if equipped) PCV filter Limited-slip differential oil Rotate tires Inspect Brake pads, rotors, drums (Correct/Replace, and linings If Necessary) Brake lines and cables Exhaust system Manual transmission oil Transmission fluid Differential oil Engine drive belts Fuel lines/connections
Is it recommended that I take care of these things? I've read in several threads about getting the microfilter cleaned or replaced, but I'm not sure about the rest. Also, is any or all of this covered by the 3-year, 36k warranty? If not, should I have these things done elsewhere?
Thanks for the input!
Old Jan 20, 2004 | 09:36 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
none of it would be covered under the 36k/3 yr. the only pertinent items i can think of are if you oil needs changing, dont deviate from the current schedule. also look into flushing the coolant and fluid change for the tranny depending on auto or manual. most everything on their list is inspections so it would be more cost effective just to have the repairs that you need.
Old Jan 20, 2004 | 01:51 PM
SkoorbMax's Avatar
Not sure how much they're asking for, but things you can't do yourself, I'd just bring to a local mechanic and have them done. Dealerships make a KILLING on people paying for these big 30k, 60k, etc. maintenance jobs and if you read through the lists of all of the millions of things they'll do, most of it's just filler and crap and other than one or two lubricant changes, and a radiator flush it's just stuff you can do in a few minutes.
Old Jan 20, 2004 | 02:35 PM
NYC TAR's Avatar
tanny flush, or drain and fill very easy
antifreeze very easy to flush
and oil change.
the only three major thing.and you can do everything yourself.
Old Jan 20, 2004 | 05:47 PM
03maximan's Avatar
If you haven't changed your in-cabin filter or balaced/rotated your tires, then you are WAY overdue. In-cabin filter ($50 carry out at dealer) should be done once a year or every 15K miles(mine was FILTHY @ 15K), tires should be B/R every 5-7k miles. Everything else is common sense, if car doesn't stop as well have brakes checked, if you see puddles of oil/coolant under the car, check for leaks.
Can't tell what year Max you have, but the dealer service intervals are not cheap considering what you get. I think the 30K is like 200 greenbacks.
Old Jan 21, 2004 | 10:25 AM
Skier's Avatar
Many local garages (if you know of one you trust like I do) will price out the same service based on Nissan's requirements. My guy comes up about 40% less on cost and actually ends up doing more from me. In the event a warrantee issue comes up you'll have the reciept to prove you kept the vehicle up.
Just a suggestion... Why pay the local STEALER more $
Old Jan 21, 2004 | 09:28 PM
ghostrider17's Avatar
Rip-Off
Agree with everyone else: the dealers SERVICE specials are all Smoke and Mirrors with a few necessary items thrown in to keep it looking good.
Stick to the service manual recommendations (you'll notice that the dealer recommendations usally DON'T, as if THEY know better than the Nissan?!) do the easy stuff yourself, and have your local mechanic perform the stuff you don't / can't do.
18k and no dealer servicings yet. Still running as well as the day I drove it off the lot....minus the brake jutter.
gr
Old Jan 22, 2004 | 01:22 AM
FanaticMadMax's Avatar
I was looking over the same thing for the 30k mile service since mine is going to be coming up soon. if it's gonna be around 200 bucks that's not bad, But what I have in my area, they gave me a service menu what they perform on and guess what's the cost here? It's freaking $385 buckaroo......Now that's a lot and a rip off.
Old Jan 22, 2004 | 06:18 AM
SkoorbMax's Avatar
[q]It's freaking $385 buckaroo......Now that's a lot and a rip off.[/q]Not surprising. These major service intervals are a great way for the stealers to get your money, whether it's nissan, chevy, or honda. They really play on people's fears, as if you're mistreating your car by not paying $400 for them to "check the brakes" and "Check condition of wipers".
my03maxima
Jul 28, 2024 07:40 AM
MaxLvr21
Oct 17, 2015 12:11 PM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
sdotcarter
Sep 2, 2015 09:53 PM
