High pitch noise when accelerate, normal?
Old Jan 26, 2004 | 08:02 AM
kclmax2k1's Avatar
Hi, I am a in this forums, just got my 2k1 gxe month ago.
I like my maxima, however, the high pitch noise just make me uncomfortable.
I can hear the noise from rear (I think) when I apply the acceleration pedal.
When I release the pedal, the noise disappears.
The noise is a small high pitch whistling (hissing) sound.
Is this normal?
Please give me some information
Old Jan 26, 2004 | 08:03 AM
twotone's Avatar
Is this normal?
All the time? A certain RPM level?
You have an intake?
Old Jan 26, 2004 | 08:21 AM
kclmax2k1's Avatar
I only hear the noise when I apply the padel (not too much, just like normal accelation, The rpm is higher than 2000.). Once I release the padel, the noise gone. I don't have a intake. Everything in my car is stock.
Old Jan 26, 2004 | 08:32 AM
twotone's Avatar
Happens to me around 2100 RPM but then goes away.. and yes goes away when I let off the gas.
If your car is stock then there is most likely something wrong with the stock intake setup and Nissan should look at it. (maybe a leak).
I wouldn't really worry too much but I would fix it.
BrandonSE's Avatar
do you have any sort of electronics (aftermarket) hooked up? If so it sounds like a form of engine noised. It happened to me from just using my friends radar detector. . Besides that i cant understand why you are getting the noise. Hope this was helpful.
brandon
Old Jan 26, 2004 | 08:34 AM
FidizzyTypeS's Avatar
brandon
I was thinking the same thing....i get feedback sometimes from my tapedeck when i drive and listen to a tape at the same time.
Old Jan 26, 2004 | 08:50 AM
kclmax2k1's Avatar
I have everything stock.
In the begining, I thought it might be some engin noise from speakers.
However, I can still hear the noise even the radio is turned off.
Is it possible that the speakers still make noise when the audio system is turned off?
I don't really sure where the noise come from.
It feel likes coming from behind.
Is it possible that the exhaust system make this noise?
Old Jan 26, 2004 | 09:06 AM
Maybe you have a leak in one of the cat's? Have the car looked it.....it's better to be safe than sorry.
Old Jan 26, 2004 | 06:47 PM
kclmax2k1's Avatar
unfortunately, I already have the dealer looked at my car and they couldn't even "hear" the noise.
It is so obvious that I can't understand why they ccouldn't recognize it.
Anyway I will try another dealer to find out what the noise is.
Thank for help
Old Jan 26, 2004 | 07:52 PM
SEdge
that's their way of saying, "we don't feel like fixing it, so we'll pretend the problem doesn't exist"
oh and i also have the same problem, and i do have an intake. but the intake was actually making a second type of whistle at the same time, and i checked all the hoses and fittings on that and got rid of that whistle, but the high pitched squeal noise is still there. happens when you rev in park or neutral also, just at partial throttle.
Old Jan 26, 2004 | 09:44 PM
kclmax2k1's Avatar
Exactly.
Any idea what it is?
Old Jan 27, 2004 | 09:14 AM
Young04's Avatar
Exactly.
don't worry about it...my 2k2 does the same exact thing...i think it's just gear whine. some cars even though they're the same model are louder than others...not much can be done about it.
Old Jan 27, 2004 | 09:50 AM
gxe2se's Avatar
I know it sound like the rear or something, but Check your belts on the passenger side. I had a similar sound when I accelerate. (i thought what the heck it this?) Anyways, I sprayed some belt dressing (NOT armor-all - its in a spray can) on the belts. I think mine ( the sound) was attributed to minor belt squeal... almost sounds like a turbo or something.
After that it went away.
Good luck and let me know if that helps.
-Anthony
Old Jan 27, 2004 | 10:21 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Mine's done that since day 1, can't stand it.
Just always play the radio or buy an intake and/or exhaust to help cover it up.
Old Jan 27, 2004 | 10:33 AM
SEdge
IceY2K1's got the right idea. music keeps it off your mind, although people outside the car can hear it. one the intake kicks in its gone anyway
Old Jan 27, 2004 | 10:54 AM
takkar's Avatar
Thats your intake. since it's cold outside..the air is less dense..and so it's harder for the engine to suck the air through the intake( or breathe)...unfortunately there is no way to fix it unless you change you intake...I get the same noise but at a much higher RPM ( roughly 3000 +)...it's just air TRYING to rush in.No worries there
Old Jan 27, 2004 | 06:15 PM
kclmax2k1's Avatar
originally post by gxe2se
I will try to do this but
What kind of belt dressing I have to use?
Which belts should I spray?
Old Jan 27, 2004 | 08:23 PM
dextterity's Avatar
i hear the same thing also, i usually always have music playing so i can't hear it, and when i don't, its a real weird sound, but i bet whoever drove your car at the dealership is so use to the sound from driving other maximas that it wouldn't click in his mind that there is a problem, enough people claim they hear the same thing so it's gotta atleast be "normal"
Old Feb 19, 2004 | 10:40 AM
Teufelhunden's Avatar
the noise went away, when i switched to K&N stock intake filter, the whistling noise is gone, but i can hear more air going into the engine, but atleast the whistling noise went away. and it only cost me 40 bucks, and it suppose to gain some power, like 1 or 2hp.
Old Feb 19, 2004 | 10:43 AM
NT2SHBBY
my car rattles, engine whistles....all the more reason I spent ~$3k for my system-to crank that bish and not worry unless u start smellin stuff, smoke starts emitting or dash lights go crazy
jerrod99_se-l
Sep 16, 2015 02:39 AM
jcvgn
Sep 10, 2015 08:03 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
Justin Kroll
Sep 2, 2015 11:06 AM
