View Poll Results: So what springs are you running on your Max?
Eibach
228
16.59%
H&R
126
9.17%
Maxspeed
92
6.70%
Tein H-Tech
91
6.62%
Tein S-Tech
166
12.08%
Groundcontrol Coilovers
0.87%
Sprint
22
1.60%
Progressive
88
6.40%
JIC
0.95%
Stock
536
39.01%
Voters: 1374. You may not vote on this poll
What springs are you running on your Max??
Old Feb 4, 2006 | 02:29 PM
  #401
cutter's Avatar
Originally Posted by Progress
Woops, forgot to check this.
Actually his prices weren't competitive enough for me. What he would have charged me ($656 Grand Total) costs more than what I ended up paying ($603 Grand Total).
Anyway ... I had a question for you guys. When people talk about bottoming out, do they mean the car hitting the bump stops, or do they mean it actually bottoming out and having an actual piece of the car hit the pavement? Isn't the idea of the bump stops to prevent suspension travel from making the car hit the pavement. I guess the cutting of bump stops is to compensate for the drop (i.e. most drops are 1-2 inches, so you cut one inch off the bump stop), correct? This way, the car will hit the bump stops before it bottoms out. Am I right?
I got my H-techs/Illumnias for like 620 shipped to my door from SCO. Just call kevin(I think thats his name) and he hooks it up.
Old Feb 4, 2006 | 02:30 PM
  #402
cutter's Avatar
I got my H-techs/Illumnias for like 620 shipped to my door from SCO. Just call Steve and he hooks it up. Steve's number 888-766-0022 Ext. 183
Old Feb 4, 2006 | 02:36 PM
  #403
Progress's Avatar
It's business time.
Thanks. I got my Illuminas already. I'm waiting on the H-techs from Redmax.
Old Feb 4, 2006 | 10:49 PM
  #404
Icondapython's Avatar
Hows the S-techs and Illuminas go together. I think couple of people have this setup in this thread. but feedback would be nice. i think i'm gonna go with this setup.
Old Feb 10, 2006 | 11:12 AM
  #405
5thgenfan's Avatar
Jeez, I've been debating what springs/shocks to get for quite some time and have spent HOURS on this forum trying to figure it out and hear from other people (and yes i went to houscor's site). I think I have it narrowed down.
Anyway, Im into a comfortable ride, crisp handling and an attractive drop.
I dont want a jarring ride or the slammed look. I basically want to escape the ugly stock wheel gap and the horrendouse ride of the stock setup.
So, would you guys all concur that H&R/Illumina is the way to go? I like the idea of adjusting but im just a daily driver who drives hard ...but goes no where near a track. is there a shock that has a comfy ride that doesnt adjust? Would the blues be too much like stock?
Old Feb 10, 2006 | 11:15 AM
  #406
cutter's Avatar
I was going to go with H&R but the drop doesn't look that good. It sags in the back and makes the front look high. So I went with teh h-techs instead and I am very happy with them. The ride on regular roads with some imperfections is fine, but it does hit hard over pot holes. I would go with the h-techs for the look, handling, and ride quality.
Old Feb 11, 2006 | 04:01 AM
  #407
ecko51's Avatar
Cutter. Did you cut the bump stops?
If so how much ?
Old Feb 16, 2006 | 09:09 AM
  #408
qballjr13's Avatar
Can anyone tell me if the struts on our cars are considered "MacPherson" type struts? I know stockers are KYB but that is the brand...is MacPherson a style of strut??
Old Feb 16, 2006 | 10:27 AM
  #409
Norm Peterson's Avatar
The front suspension on your 5th gen is, generically, a "MacPherson strut". In Earl MacPherson's original design, the strut/shock/spring assembly is bolted to the steering knuckle and mounted directly to the top of the strut tower. There is no upper ball joint or upper control arm. You are correct about brand names being without meaning as far as the description of suspension type is concerned.
Strictly speaking, no rear suspension strut is a MacPherson strut, as there is no requirement for active steering involved. If you see what looks like a MacStrut on a rear suspension, it's more properly labelled a "Chapman strut", after Colin Chapman (and early Lotus usage).
But since the rear suspension on the 5th gen is a twist beam arrangement, what looks like a strut/spring/shock unit has no particular name and is more closely related to a coil-over design than any named strut configuration.
Norm
Old Feb 16, 2006 | 10:40 AM
  #410
qballjr13's Avatar
Norm
Wow, thanks Norm. So does that mean if my extended warrenty specifically lists MacPherson strut assemblies that it wont cover the rear struts? And if it lists them as "strut assemblies" would that include the springs? Should the spring be replaced if the strut is replaced? Is this standard practice?
Old Feb 16, 2006 | 11:07 AM
  #411
As far as replacing the springs goes, when a shop replaces a strut, almost all of the time they simply transfer the old spring to the new strut. Understanding that the technician is very likely to not bother checking the spring for straightness or whether it's somewhere near its specified free length once removed - unless they're way off - is part of this.
As to the warranty wording, I think that would need very close reading and perhaps an official Nissan interpretation or other legal definition. That said, I wouldn't expect any such protection to cover the fronts but not the rears.
Norm
Old Feb 16, 2006 | 02:54 PM
  #412
vastmax's Avatar
after i sell my k-sports (hint hint)... i will be getting h&r's and illuminas
Old Mar 2, 2006 | 04:25 PM
  #413
rchun08's Avatar
sprins
So i have been on H&R spring and illuminas for about 30,000 miles now.
Got g35 coupe rims with 235/40/18..on regular roads its magic..handling,turns,everything is improved over stock
only thing is the wheel gap...As Cutter mentioned, the front wheel gap is just too big..
Also when i hit those potholes or just LA roads in general I get large thuds!! when I hit them. So i am thinking of changing to H Techs because if I am going to deal with the thuds!! i might as well get an even drop!! the roughness is not corrected even if i was on 1/1 setting./ right now I am on 3/4 because it seems more floaty on 2/3 or even 3/3
anyone know where i can get H techs for cheap!! or does anyone want to trade
Old Mar 6, 2006 | 08:10 AM
  #414
illlojik's Avatar
I C U
Has anyone bought Springs and struts from Ebay. I'm looking to get some H-Techs and HP Blues from there for a total of $470 vs SCO's and other websites' prices of $639 and up. I'd just like to know if anyone has any experience purchasing spring from Ebay, thanks. Oh yeah, I'm riding stocks now, but as you see, my obvious choice is to go with H-Techs since I hear so much rave reviews. Even and clean drop, decent ride, great price.
Oh another thing...>>>> SO I dont post *****::>>>> HAs anyone here only dropped thier front just to get rid of our 4x4 wheel gap?
_________________
Sterlin Silver Mist 5th Gen Driver
Old Mar 7, 2006 | 01:30 AM
  #415
illlojik's Avatar
I C U
Bump
Originally Posted by carabuser
how long have you been riding on these? how are the stock shocks holding up?
Sure its an old post, but I'm interested. just ordered my HTechs and am waiting for a lil more cashflow before I cop new struts. I'd love to know how they ride on shock struts.
By the way, anyone on the board only have aftermarket struts at the front of thier car, if so, what springs, what kind of struts and hows the ride? Thanks a bunch in advance.
Old Mar 11, 2006 | 07:59 PM
  #416
IWNTMORHP!!'s Avatar
CAN YOU PUT IT ON THE WALL?
here's the Vogtlands after about 6000mi. nice drop w/minimal difference f/r
Old Mar 17, 2006 | 01:51 PM
  #417
illlojik's Avatar
I C U
Finally
Finally I can join the Ranks of the Suspension gods of this forum. MAbey not all of that. But I finally got my Illuminas today. Shipped out same day from Ebay, but UPS took FOREVER(train delays, bombs, Steven Segal, whatever it was). My whole suspension setup is finally here. (H-Techs)...well, almost, I still need some new dustboots/bumpstops. But this will be my project during the weekend/week. Wish me luck with the install.
______________________________
EDIT: Its Sat, and its frigging FREEEEEZing in NY. I wont be working on and install this weekend aparently. sigh. Mabey I can find a mech. who'll do it for cheap.
Old Mar 18, 2006 | 08:02 PM
  #418
dr-rjp's Avatar
Originally Posted by illlojik
....My whole suspension setup is finally here. (H-Techs)...well, almost, I still need some new dustboots/bumpstops. But this will be my project during the weekend/week. Wish me luck with the install.
Good luck, Ben! I'll have to experience your setup vicariously, as I had to sell my unused H-Techs and Illluminas (unexpected money problems)
Old Mar 24, 2006 | 06:07 AM
  #419
illlojik's Avatar
I C U
NAme is actually KRIS, but thanks anyways. My install was successful, handling is great. So FarI've only tried 2 settings, 3/4 and 4/4 on the illuminas. The back struts are kind of hard to get to to adjust (Damn black shielding). I just put my 18s on, havnt tested the ride with them on yet, but I'll probably have to set everything to 1/1 in order to stand the ride. NY roads are a b!+(#
Old Mar 30, 2006 | 09:36 AM
  #420
dr-rjp's Avatar
Not sure...but they feel like bedsprings.
Old Apr 10, 2006 | 04:30 PM
  #421
jonlawrence's Avatar
TeinS
They are the lowest spring, this is why I bought them.
I really don't think the ride is bad at all.
After having 2 mustangs lowered with Intrax maybe why it doesnt feel bad.
Old Apr 11, 2006 | 03:30 PM
  #422
RY2KMax's Avatar
Eibach & GR2s
Old Apr 11, 2006 | 07:32 PM
  #423
DaBoxSE's Avatar
Figured I throw another set of props for the Maxspeeds and GR2s.
Old Apr 26, 2006 | 10:06 AM
  #424
Max_Shizo's Avatar
I have an 00 se. I am getting ready for springs. Has anyone heard of dropzone springs and if so do they suck?
Old May 6, 2006 | 11:11 AM
  #425
Spartacus2002's Avatar
stock here
Old May 6, 2006 | 03:36 PM
  #426
Originally Posted by Max_Shizo
. . . Has anyone heard of dropzone springs
Yes.
It's not that simple of a question, so I won't even attempt a guess without spring rate and drop info and some idea about your shocks. Please provide the Maxima OE spring rate values as a baseline.
Norm
Old May 6, 2006 | 04:55 PM
  #427
TopSpeedNY's Avatar
tein s techs with tokico illuminas....
Old May 9, 2006 | 09:38 PM
  #428
Max_Shizo's Avatar
Not trying to be a jerk but i could care less about load rate and all that bs. All i want to know is if they are half way decent. I mean do they sag after the first 30 days??
Old May 10, 2006 | 03:21 AM
  #429
No feelings hurt here.
I contend that the full definition of the term 'suck' as applied to springs also includes the car's daily ride characteristics. IOW, the part about lowering springs that you'll have to live with when you're actually using the car to go somewhere.
People have been making all sorts of poor choices about springs for longer than I can remember (and I do have a few years to call on). Mostly, those folks end up either constantly griping about a poor ride or sucking it up and keeping quiet rather than admit that they made a questionable decision.
A somewhat more informed thought process before shelling out any $ in this case gives you a better chance of ending up with the ride height that you're looking for combined with a ride that you can live with rather than 'have to put up with'.
Norm
Old May 10, 2006 | 07:21 PM
  #430
irish44j's Avatar
retired moderator
Had Maxspeeds....recently installed H-Techs....switching back to Maxspeeds as soon as I get the time......
linear springs, FTW.
Old May 10, 2006 | 10:04 PM
  #431
14psisupra's Avatar
after installing h-techs on stock struts is an alignment needed?
Old May 13, 2006 | 09:40 AM
  #432
14psisupra's Avatar
can anyone tell me before i get them in
Old May 13, 2006 | 10:22 AM
  #433
If your ride height changes more than a few mm, yes.
Norm
Old May 23, 2006 | 11:13 PM
  #434
Max_Shizo's Avatar
ok. so i received my dropzone springs yesterday. I have been reading different things about people cutting the bumpstops. There are no instructions with my springs so how do I know how much to cut off? The dropzones claim to drop my car 2" inches all around.
Old May 23, 2006 | 11:58 PM
  #435
sciff5's Avatar
Should be installing Eibachs/Illuminas tomorrow. Knock on wood/cross fingers
Old Jun 5, 2006 | 03:47 PM
  #436
sciff5's Avatar
Got the Eibachs on and they ride great. I dont know how they got the reputation of being a hard riding spring.
plus performance is great and the drop is pretty close to perfect
Old Jun 6, 2006 | 03:22 AM
  #437
Not everybody's tolerance for a ride that's stiffer than stock is the same, and some may frequently drive on roads that are bad enough to put a lowered car into the bump stops more frequently. Don't forget that people making complaints tend to speak with louder and more persistent voices than those who are satisfied with their choice(s).
Norm
Old Jun 6, 2006 | 10:39 AM
  #438
sciff5's Avatar
Norm
I live in pothole ridden New England and with the Eibachs I bottom out no more than when I was stock. the only time I could see my setup being too stiff is inner city driving where potholes can be 4+" deep with sharp edges. There is a pothole around here like that and it would bottom my car out even when I had stock suspension
Old Jun 6, 2006 | 03:08 PM
  #439
It's not that the setup would be too stiff per se; more likely it is not stiff enough for the remaining amount of bump travel and whatever given bump severity. That lets you crash into the stops, where the effective suspension rate can skyrocket (most bump stops get progressively stiffer pretty quickly). True, the stiffer the spring the firmer (harder) the ride, so obviously there is a "sweet spot" of spring stiffness vs design bump severity (where you use up all of the travel without hitting the stops or only contacting them lightly, thus defining a minimum spring stiffness for a given bump). Look at the Baja off-road race trucks for an extreme combination of stiffness and travel.
Norm
Old Jun 6, 2006 | 06:37 PM
  #440
EastSideMaxima's Avatar
A swift Bimmer driver
What do you guys recommend for a daily New England driver? '02 Max with stock suspension at 45k... now in need of rear suspension! I am also planning to get the fronts done while I'm at it!
I was thinking of Eibach + Tokicos!
