View Poll Results: So what springs are you running on your Max?
Eibach
228
16.59%
H&R
126
9.17%
Maxspeed
92
6.70%
Tein H-Tech
91
6.62%
Tein S-Tech
166
12.08%
Groundcontrol Coilovers
0.87%
Sprint
22
1.60%
Progressive
88
6.40%
JIC
0.95%
Stock
536
39.01%
Voters: 1374. You may not vote on this poll
What springs are you running on your Max??
Old Aug 15, 2006 | 05:31 AM
  #481
MidN1te's Avatar
hmm... i'll check into that.. Hey Puppet master, can you contact me, i have a huge question on something and i cant pm you cuz i dont think i have enough posts.
Old Aug 15, 2006 | 05:34 AM
  #482
Puppetmaster's Avatar
You do now with 15 posts.... wait for a bit and your status should change.
Old Aug 15, 2006 | 05:37 AM
  #483
MidN1te's Avatar
i gotta wait til 25 dont I? grr..and then i can pm you right?
Old Aug 15, 2006 | 05:39 AM
  #484
You can PM one hour after you hit 15 posts.
http://forums.maxima.org/announcement.php?f=10
Old Aug 15, 2006 | 05:44 AM
  #485
MidN1te's Avatar
wow.. your like.. really on top of things! hahaha
Old Aug 17, 2006 | 06:18 PM
  #486
F8thless's Avatar
Maxspeed Springs
How Is The Handling And Feel W/ The Maxspeed Springs With Stock Struts? Durability?
Old Aug 17, 2006 | 06:40 PM
  #487
illlojik's Avatar
I C U
Handling = MUCH better, of course any aftermarket setup is better that stock
Feel = Very Much like stock which is a plus. However on stock struts the ride is a bit bouncy.
Durability = I've only had my setup for a few weeks. But read through the post or search and you'll see a couple orgers with stock struts/maxspeeds going on for over a year now.
Old Aug 17, 2006 | 07:56 PM
  #488
Skylowmax's Avatar
Progress...So far So good
Old Aug 21, 2006 | 12:59 AM
  #489
carrrnuttt's Avatar
I didn't have the time to read through all 17 pages, but no Megan as a choice? That's what I'll be getting in about 2 weeks.
Old Aug 30, 2006 | 12:07 PM
  #490
felon's Avatar
im currently saving up for some illuminas......love the simple adjustments, i have a friend who track races his is300 with illuminas, and man his car handles great on the track
Old Sep 15, 2006 | 11:07 AM
  #491
illlojik's Avatar
I C U
I may be the only one who thinks that adjusting the rear illuminas are a pain in the as's. Especially due to the black shielding.
Old Sep 15, 2006 | 12:32 PM
  #492
sciff5's Avatar
It is a pain in the *** but you could deal with the Koni Yellows and then you'de have to climb under the car which is even worse
Old Sep 17, 2006 | 04:54 PM
  #493
dr-rjp's Avatar
AGX users: What setting do you use, and with which springs?
For KYB AGX users:
What setting did you try first before settling on your current one?
Old Sep 29, 2006 | 09:46 AM
  #494
zenjia 03merlot's Avatar
vogtland springs
vogtland springs are mighty nice, handling is night and day from stock se springs. running on stock shocks f/r, noticed a 'tokico' brand stamp on the strut housing on the fronts but not the rears, seems fine so far. clean and fairly even drop.
Old Oct 1, 2006 | 07:58 AM
  #495
Raf2kMax's Avatar
Originally Posted by 96_vqmax
I got H&R and GR2,the ride was better than oem,but the rear spring was kinda soft imo.
you RIDE BETTER than stock with the H&R's and GR2's compared to stock..or just handle better?
im looking for a more comfortable ride...my AGXs are almost done i think
ride is really harsh with the B&G springs (these were supposed to be comparable to h&r's i think)
Old Oct 1, 2006 | 08:28 AM
  #496
VQuick's Avatar
Chassis Freak
No lowering spring is going to ride better than stock, unless you take measures to regain the lost travel (shortened strut bodies, thinner strut mounts, relocated ball joints). GR2s are not that great so the ride will definitely be worse than stock when paired with lowering springs.
http://e30m3performance.com/myths/travel/travel.htm
Old Oct 1, 2006 | 11:53 AM
  #497
illlojik's Avatar
I C U
checked that out. very good info. Question is, how would we go about doign that? EX: shortened strut bodies, relocating spindle upwards, etc??
Won't you get the same effect cutting the bumpstops?
EDIT: read more, they did mention the whole stiffer spring and bump stop cut trail and error issue.
Old Oct 1, 2006 | 01:24 PM
  #498
VQuick's Avatar
Chassis Freak
Well, Motivational at least used to make shortened front strut bodies; Mzmtg on the Org makes simple replacements for the rear strut mounts for 4th gen and probably 5th gens (gives you almost an inch of lost travel back); and there's a thread right now in the Suspension/Brakes forum about ball-joint extenders which will improve handling immensely if you have lowering springs.
Also check out the rest of that M3 site; it's got tons of good technical info that applies to most cars.
Old Oct 6, 2006 | 06:44 AM
  #499
dr-rjp's Avatar
SECOND THOUGHTS: How many went back to stock??
I was curious as to how many members switched back to stock springs after initially changing over to lowering springs?
I've seen a lot of "Want to Buy" ads for stock springs (as well as requests for stock springs made to people parting out their cars), and I was wondering if many of those looking for stock springs had installed lowering springs and then decided that they wanted to go back to stock.
So, if you have made the switch back to stock, or are contemplating it, please chime in and briefly state why you decided to go back. Thanks in advance.
Old Oct 6, 2006 | 11:01 AM
  #500
illlojik's Avatar
I C U
I'm still deciding on wether or not I want to go back to stock springs. My reasons being that NY streets are horrible, Pot holes+2 or more passengers=Horror. The maxima already drives like crap on bad streets stock, no better lowered. Damn the Friggin 4x4 front look. But Ride quality>*
Old Oct 14, 2006 | 03:35 PM
  #501
dr-rjp's Avatar
Stuck to stock and glad I did.
I guess that I got really used to the cushy ride of stock springs and struts because I installed KYB AGX's today, set them to 2 and 4, and I thought my fillings would fall out after the ride. And I'm using them with the original stock springs!
I've got a bad back, so I really do need the cushioning.
I'm glad that I did not add lowering springs -- that really would have lowered the boom on me. Dialed the AGX's back to 1 & 2, and the ride now feels supportive but not stiff.
Old Oct 14, 2006 | 05:14 PM
  #502
VQuick's Avatar
Chassis Freak
AGXs are known not to give a good ride. You would be happier with Illuminas, FWIW.
Old Oct 27, 2006 | 02:36 PM
  #503
absoundlab
kyb gr-2 and tein s tech
Old Oct 28, 2006 | 09:07 PM
  #504
Jake R's Avatar
Illumina strut length?
Does anybody know if Tokico Illuminas are shorter than OEM? The Tokico HP shocks are the same as OEM and don't work well with shorter springs, even with the bump stops trimmed way back (frequent bottoming). I have these shocks and Eibach springs, a crappy setup, and I'd like to go to Illuminas if I can confirm the length is shorter than OEM. Stillen has been less than helpful on this.
Old Oct 29, 2006 | 01:43 AM
  #505
VQuick's Avatar
Chassis Freak
If you are bottoming out, don't cut your bump stops, that makes bottoming out a lot harsher. FWIW, I measured the exposed piston length of my Illuminas (4th gen) when off the car and I think it was 8.5 inches.
Old Nov 12, 2006 | 04:48 PM
  #506
pbn85's Avatar
I have H&Rs all around but Im getting rid of the fronts and putting Htechs there instead. I just dont like the cosmetic factor when it comes to H&Rs...but when it comes to the ride and handling, I LOVE them
Old Nov 17, 2006 | 11:40 AM
  #507
Trurida18's Avatar
stock!
my front left shock creaks a lil bit though
Old Nov 20, 2006 | 10:50 PM
  #508
biglux1's Avatar
Wow the S-tech springs were really easy to install, it took me and a friend about 2 hours but i found out my struts are completely blown
Old Nov 21, 2006 | 06:31 PM
  #509
abraxus22's Avatar
I just bought an 02 max with under 50K miles a month ago and I love it. I took the advice of another forum member and only replaced the front Springs with H&R. Cosmetically the car looks better (because it isn't jack-up in the front anymore) and it still rides the same.
Old Dec 15, 2006 | 11:29 AM
  #510
C P Squared's Avatar
I want to see some close up pics with some people maxima with Tein S-Tech springs and what struts you are using with them. Would they fit on an 00' Infiniti i30
Old Jan 9, 2007 | 08:11 PM
  #511
Revs2Hard's Avatar
BARF
DZ springs and GR2 struts.
Anyone selling a set of S-Techs out there?
Old Jan 10, 2007 | 12:57 PM
  #512
g8rb8cpl's Avatar
Newbie question
I am stock under the car...Looking to run progress springs and GR2's but a little befuddled on something...Do they run struts front and rear on these cars or struts up front and shocks in the rear?
Old Jan 18, 2007 | 08:48 AM
  #513
VQuick's Avatar
Chassis Freak
Springs/struts (MacPherson) front and rear.
Being stock under the car is better than being stuck under the car!
Old Jan 18, 2007 | 03:41 PM
  #514
GOLD00GXE5SPD's Avatar
im riding h&r front and h tech rear on 3/3 illuminas and progress rsb.. the handling is absolutely amazing, crisp steer-in and very little roll through a fast corner. i couldnt be happier with the setup, pics are up on the other suspension forums. im never going back to stock
Old Jan 30, 2007 | 08:39 AM
  #515
MaximumPower01's Avatar
Anyone heard/run....."NEX GT Coilovers"
http://cgi.ebay.com/ebaymotors/NEX-G...spagenameZWDVW
And JDM's.....the el cheapo route...?
http://cgi.ebay.com/ebaymotors/S-NIS...spagenameZWDVW
THoughts on these?
(as im half tempted to save 700 bucks and try the JDM's.........eeeek!)
Old Jan 30, 2007 | 08:47 AM
  #516
whazzzzuup's Avatar
THoughts on these?
Those NEX's do not have camber adjustment plates. When the coilovers have the ability to lower the car that much, camber plates should be included.
The JDM's "coilovers" look like they were made in China. You should not cheap out on suspension stuff. When the car is at a standstill, it may look "cool," but it won't be "cool" when your car will be bouncing after every little bump in the road.
Old Jan 30, 2007 | 06:05 PM
  #517
VQuick's Avatar
Chassis Freak
What he said.
Old Feb 10, 2007 | 12:10 PM
  #518
babyboyws6's Avatar
Progress Springs (1.7 front 1.5 front.. about) w/ Tokico Illuminas. while sitting on 18x8 G35 coupe OEM rims wrapped in 235/40/18 Toyo's... Do you think i would experience any Rubbing issues even with a full car?
Old Feb 11, 2007 | 02:13 PM
  #519
Revs2Hard's Avatar
BARF
Here is another pic of the DZ's w/GR2's
Old Mar 5, 2007 | 05:33 AM
  #520
Nissanx54's Avatar
anyone have any advice on lowering springs? i was looking at getting Teins but have read bad reviews on them being too soft and the front end bottoms out. not looking to go very low just something to make it handle better and have a more aggressive look.
