Squeal on startup from Gearbox...
Old Jan 27, 2004 | 08:02 AM
Driven EF9's Avatar
whenever the car is cold and I start it up, there's the squeal on the driver's side near the gearbox, after a second, it stops.
I'm thinking it could possibly be the starter... but, what else is on the driver side of the engine bay that would make that squeal at startup?
Finally, what does a starter typically cost?
it's a 2000 SE auto.
Old Jan 27, 2004 | 08:45 AM
spirilis's Avatar
Mine's making a noise like the starter is sticking... DAVEB told me over the phone that the pinion gear is the most likely culprit, and a new pinion gear costs almost as much as a new starter. I didn't ask how much the new starter cost.
Dave said the problem first starts intermittently (in my case, at <15F temperatures), but eventually it will do it even when it's warm out...
Old Jan 27, 2004 | 09:16 AM
SkoorbMax's Avatar
Is this a "squeal", or a high pitched "scrape" sound that you're experiencing?
Old Jan 27, 2004 | 09:17 AM
BrandonSE's Avatar
Its the starter needing to be regreased. There was a member on the org who did a write up on regreasing the starter, and its not that complicated. He even had sound clips to make sure you had the symtom. I have the same thing you do and trust me this works. No need for pinion gears just some grease and time.
brandon
Old Jan 31, 2004 | 12:23 AM
Edward Lee's Avatar
Where can we get this write-up on regreasing the pinon gear? I have a 2kSE and it just started making that same noise, right at startup for a few seconds.
Old Jan 31, 2004 | 01:35 AM
KCMichaelM's Avatar
http://forums.maxima.org/showthread....er#post1775009
You're welcome Now donate some $$$ and search yo-self
Old Jan 31, 2004 | 04:36 PM
Edward Lee's Avatar
Thanks for the link. BTW, the Org. is not accepting donations at this time and they haven't been for awhile. Thanks for the unwarranted lip service.
Old Jan 31, 2004 | 04:41 PM
Jaws's Avatar
Someone gives you help, and then you backstab them. Nice.
Old Jan 31, 2004 | 04:48 PM
Edward Lee's Avatar
It's the American way.
Old Jan 31, 2004 | 05:00 PM
KCMichaelM's Avatar
I donated less than a month ago... Just so ya know!
Old Jan 31, 2004 | 06:03 PM
03maximan's Avatar
Had to be longer ago than that, I tried around christmas and mine was refunded.
And just because you did, don't mean eveyone has to.
Old Jan 31, 2004 | 06:10 PM
03maximan's Avatar
To get back to the topic, I hear the scaping sound. Only at very cold temps ( like now). Take it in and have it replaced under warranty maybe? Or nothin' to worry about?
Old Jan 31, 2004 | 07:48 PM
MmaximaSE01's Avatar
could it be as simple as the belt squealing? hmmm
Old Feb 11, 2004 | 08:32 PM
ZAJOBA's Avatar
If you hadn't done it yet, check this site > Link
It's 97 maxima , I believe, but should be smth similar.
I'm planing to do mine soon as well..
Thanks foodmanry for write up.
Old Feb 11, 2004 | 10:03 PM
Edward Lee's Avatar
Since I can't donate at this time, here is my contribution to the Org. I just got my car back from the dealer and they told me that the starter sound is from the starter gear not retreiving back to its position as soon as it should. It will get progressively worse, however, you should be able to live with it for a few years. It is not covered under the 5/60 engine drivetrain warranty. I argued that it was an essential part to the engine and they wouldn't go for it.
Old Feb 17, 2004 | 09:33 AM
pegasus1113's Avatar
Grinding noise on startup
Is this the same issue discussed under the timing chain thread (283116)? There is a TSB for this but it involves significant engine work that most of us would rather not endure. Mine happens occasionally for about a second - still not sure what it is but it doesn't sound good.
02PearlSE
Oct 7, 2015 02:12 AM
msellas
Sep 23, 2015 09:16 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
bennuss
Sep 11, 2015 05:55 AM
305head
Aug 26, 2015 09:03 PM
