Just picked up a set of ignition coils
Old Jan 27, 2004 | 08:17 AM
Chops2101's Avatar
Called Southpoint Nissan in Texas. Total w/ tax and shipping was $337.93. Does this sound about right? This is w/ a 20% discount he said he gives people referred from maxima.org. I gotta say, the guy was much better than any dealers around my area.
Old Jan 27, 2004 | 08:25 AM
[maxi-overdose]'s Avatar
kinda pricey, IMO. if you shop around on ebay, you might get them all for $250 plus shipping.
ask Dave B on this board. he works at a nissan dealer and he gets us good deals all the time.
Old Jan 27, 2004 | 10:01 AM
Chops2101's Avatar
Well, its too late now, I ordered them this morning. I couldn't wait any longer. It is getting to the point where my car is missing every time I run it. Is it possible that I have done any damage to it like the cat, valves, etc? Thanks!
Old Jan 27, 2004 | 10:21 AM
possibly just the cat...but it still better than pinging. you can always do an oil report and see if there's any exscessive wear on your engine components.
when the engine misses, you just shoot bunch of fuel into the engine with out igniting it. Check your plugs, it might look wet too.
Old Jan 27, 2004 | 10:28 AM
smithson's Avatar
Does anyone have detailed instructions on how to replace the ignition coils on a 2k? I understand it's not too complicated of a process.
Old Jan 27, 2004 | 10:39 AM
costcowholesale's Avatar
my cars been misfiring on & off for 2 months now.... replaced 1 coil, it was ok for a bit, then 2nd coil goes... then the third one goes too! just fixed all of them yesterday... I noticed that when the car misfire it smells, I guess unburn fuel gets shot out of the exhaust? did I do any damage to the car? hopefully the cat isn't too messed up since I have to do inspection in April lol
Old Jan 27, 2004 | 11:07 AM
SkoorbMax's Avatar
It's not complicated. There are three ignition coils at the back of the engine, and three at the front.
Rear three: With a socket set and an extension neck, so that you can reach the bolts, unscrew the brass colored bolt holding in each ignition coil. Go one at a time. You will need to unhook each coil from its wire harness (just press in, and wire-socket will pop off) and then, with the coil unhooked, and the bolt taken out, just yank on the coil until it comes out. I personally used needlenose pliers and grabbed the plastic at the top of the coil. You'll hear a popping sound. Insertion is opposite of removal.
As you move towards the driver's side of the car, it will become harder to get at the coils. The final one for me required me to unscrew the clamps holding in place the throttle and cruise control cables. Use an open-ended or adjustable wrench for that. Just loosen them a touch, and you'll be able to get the cables out of the way to access the last coil.
Front three: Same as the rear, but access is infinitely easier. The only extra step is to remove the engine cover, which is held in place by 3 (I think only three) screws. To unscrew these you'll need a set of alan keys.
Old Jan 27, 2004 | 11:21 AM
spirilis's Avatar
erm... DAVEB is from South Point Nissan...
Maybe he talked to somebody other than Dave?
I can see $336 if he did overnight shipping or something... I bought 6 coils + 6 copper spark plugs from DAVEB with FedEx 2-day and it came to around $326 total
Old Jan 27, 2004 | 11:39 AM
so does it happen to the same cylinder?
I dont think it will do any harm if you dont hear any pinging. if there is, probabily it just the cat and a cat is always cheaper than an egine rebuilt.
really? I didnt know that
Old Jan 27, 2004 | 12:25 PM
Fezzik's Avatar
Well it is safer to buy ignition coils off of SWA or dave burnette. If you buy off ebay make sure the coils have the silver dot on all of them. That shows the updated coils.
Old Jan 27, 2004 | 02:06 PM
TZapper's Avatar
I wouldnt buy the coils from eBay. I want to make sure they are genuine, new and updated opposed to old defective ones.
I got them from Dave for $309 shipped. No tax since I am in CA.
Old Jan 27, 2004 | 08:27 PM
cabernet's Avatar
Here's a site from a fellow Maxima.org member that I have bookmarked. It's for spark plugs but you need to remove the coils to get to the plugs.
http://www.nissanx.net/tanman/
Old Jan 30, 2004 | 10:42 AM
Chops2101's Avatar
I got the coils today. Which ones are front and rear? I am assuming the ones in the long skinny box are the rear, and the others are the front. am I correct?
Thanks!
Old Jan 30, 2004 | 10:58 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
Dave B is not the screen name of the Nissan Parts guy. The nissan parts guy S/N is; > DAVEB <
sake1bs
Sep 19, 2015 09:32 PM
MaxLife17
Sep 8, 2015 02:36 PM
evonder73
Sep 1, 2015 02:21 PM
maxima297
Aug 3, 2015 12:50 PM
