frankencar exhaust install...
6yrs old=36,500 miles :)
![](https://maxima.org/forums/images/smilies/support.gif)
well i just installed it and it took me about 45 minutes with the help from a friend. and it only took a week to arrive...WOW!!! ANYWAY..great looking exhaust, almost as quiet as stock..just a little deeper sound which is exactly what i wanted.
i had no problems at all with the install. fit perfect. I HAVE A FEW PICS ON MY CAR DOMAIN SITE.
![ThumbsUp](https://maxima.org/forums/images/smilies/thumbsup.gif)
nice to hear no fitment problems. I met up with steve from frankencar a couple weeks ago and picked up one of their b pipes to match with my stillen rear section. Its not gonna go on until spring comes tho. Hopefully my install will be problem free. Its a really nice looking pipe.
-Steve
-Steve
Originally Posted by harmbone2k2
Is My Sig Not Showing Up With All My Upgrades? If Not Then 92 Se-r 02 Se Yes I Do Have A Y-pipe.
-J
looks kinda crooked
http://images.cardomain.com/member_i...05_11_full.jpg
other then that looks good, get soem sound clips
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
Do you have issue w/the muffler hitting the rear frame when the car hits a bump? I noticed that the stock hanger is too soft to support the muffler and doesn't control the bouncing/vibration of the muffler too well. I have to modify the existing hanger (stiffen up w/clamps) until I can find a better or stronger rubber hanger.
you will have to call cattman and order the y-pipe...they have it...and i used a lift to install it...yes it is angled slightly because it is not a straight though exhaust.
Let me ask ya'll a question???? Why on frankencar web site they show 2 mufflers. One muffler looks like a stock 2k2 but just in chome, and the other looks like a magnaflow. When I order my catback they better not give me that CHOME 2k2 muffler, or we going to have BEEF.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
the clamps did help keep the muffler from hitting the heat shield...that exhaust is not light...i am going to buy 2 more clamps just to make sure it is nice and tight. and Ghase...the exhaust does look a lot bigger in person
![Slap](https://maxima.org/forums/images/smilies/slap.gif)
Originally Posted by VMaximus02
FYI: You can use the clamp (2-given) from the installation kit to wrap it around the left rubber hanger and adjust to align the muffler straight.
BTW, where are the sound clips?
Originally Posted by chigga
yeah hook it up when you can i want to hear the frankencar, i'm still waiting on my got damn intake ![BangHead](https://maxima.org/forums/images/smilies/banghead.gif)
![got me](https://maxima.org/forums/images/smilies/ne_nau.gif)
Originally Posted by 2k2whitemaxi
please send them to somone that will post them i want to hear ...thanx
-J
-J
![GrinNo](https://maxima.org/forums/images/smilies/grin_no.gif)
Wrap the hose clamp around the rubber hanger at the outer right side of the muffler, at the end where the b-pipe and the muffler are connected. Screw the hose clamp up tight emcompassing the hanger. Then test drive the car and adjust the clamp until you hear no strange noises when driving or hitting bumps on the road. Also, the stock hanger at/next to the right side of the dual tip is too soft for this stainless steel muffler (quite heavy). The existing rubber hanger allow too much vertical rebounce and this undamped movement causes the muffler to hit the heatshield or the rear metal frame. The best solution I'd found is to stiffen/re-enforce the rubber hanger w/2-smaller hose clamps by wrap them horizontally around the hanger. This will help to control the vertical movement or to increase the damping rate for the rubber hanger. In addition, you can shift or adjust the muffler with a crowbar to avoid the side of it from touching the heatshield.
Hope this help!
06-06-2017 02:01 PM
Mahmuth
09-25-2015 10:08 AM
