Lights get brighter under acceleration
Old Jan 29, 2004 | 03:13 PM
BennysMAXIMA's Avatar
Whats up all?
Had a problem with my 2000 SE no start. Got a new battery and it seems it fixed the problem. Now when I rev the engine my lights get brighter! Anyone have any ideas?
Thanks in advance!
Old Jan 29, 2004 | 03:30 PM
Cubanato's Avatar
Joo wanna play??......ok we go to war
Originally Posted by BennysMAXIMA
Whats up all?
Thanks in advance!
maybe u need a new alternator
-J
Old Jan 29, 2004 | 03:31 PM
-J
That is what i'm thinking! I am going down to Auto Zone now and see if they can test it for me!
This blows!
Old Jan 29, 2004 | 03:32 PM
s_hinerman's Avatar
definately sounds like the alternator is going bad. you might have a little bit of time but if it is cold there it will go even quicker.
Old Jan 30, 2004 | 10:30 AM
MaScott's Avatar
Particularly, it's likely to be the voltage regulator that's integrated into the alternator. They usually recommend to replace the whole alternator though...
Old Jan 30, 2004 | 10:48 AM
† ErV †
so do mine. and on all cars i have pretty much been in. it's normal, since the alternator does not produce peak output at idle. lights are sensitive and will reflect any change in voltage.
one thing you can do is, somehow (maybe go beg dealer) is to increase idle to about 1200, which is not a good idea on this car.
i know police package cars get around that by having a higher output alternator spinning off a separate belt so it turns faster, and also the idle is bumped up by the ECU under load to about 1300.
Old Jan 30, 2004 | 02:25 PM
FidizzyTypeS's Avatar
Do you have an upgraded audio setup in your car? If so it's pulling too much juice. I would reccommend getting a cap or possibly an extra battery.
If thats not the case change out your alt.
Old Jan 30, 2004 | 02:33 PM
2k3TitaniumSe's Avatar
That's crazy, the volume of you system should get louder.
mvm062
Nov 30, 2020 09:00 AM
ballerchris510
Sep 10, 2015 09:35 PM
Maxima30
Sep 7, 2015 06:13 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
