question about engine
Old Jan 31, 2004 | 10:35 PM
krmaxima's Avatar
just wondering if dirt got in it. say like dirty oil or some dirt got in somehow. is your engine phucked?????? just thought about it and really didnt know the answer.
Old Feb 1, 2004 | 07:22 AM
Ferbs02SMMax's Avatar
You could get some foreign particles in your engine if you were running without an air-filter. An organic particle like dirt wouldn't do much harm, it would get burned up in the combustion chamber. Something larger like a pebble/rock that were to get into the combustion chamber, and you might be in bigger trouble.
Old Feb 1, 2004 | 08:48 AM
housecor's Avatar
Agreed. Also, a few who have swapped out their intakes have destroyed their engines by allowing small peices of metal into their intakes. On the oil end, how exactly would you get foreign particles in your oil? I mean, it comes straight out of the bottle into your engine. Unless your funnel was filthy...
Old Feb 1, 2004 | 08:59 AM
spirilis's Avatar
Even then, the oil filter should suspend the particles, so long as they don't damage the oil pump first... and some of those should get rejected by the oil pickup strainer, eventually floating to the bottom of the oil pan
Old Feb 1, 2004 | 09:02 AM
Zero Deuce SE's Avatar
If you allow dirt in sufficient quantities to enter the engine, it will wear the cylinder walls and piston rings like sandpaper would. Dirt is abrasive. That's why the air filter is the most important filter on your engine. For example, if you were to drive your car on dusty roads for a few hours w/o an air filter, your engine would be toast by the time you finished driving.
Old Feb 1, 2004 | 10:22 AM
krmaxima's Avatar
so how would u fix this??? just to be on the safe side. like engine flush????
Old Feb 1, 2004 | 11:03 AM
The key is to prevent the dirt from entering in the first place. Once it gets into the cylinders, it's too late to do anything about that dirt. Just ensure that you have a properly fitted air filter assembly at all times. Engine flush is mainly for engine deposits like varnish and sludge. I don't see any way it could remove dirt from the cylinders.
MAXSE5SPD
Sep 17, 2022 04:00 AM
Johnny9595
Sep 3, 2015 05:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
Hawkeye61
Aug 12, 2015 06:45 PM
