suspension noise help (strut bearing?)
I'm getting a little banging noise in my suspension only under hard throttle from a stop. It sounds like the Ypipe banging a bout5-10 times. I also notice the noise when I go over a small curb or pothole slow.
Stock struts look good and I have maxspeed springs. I haven't taken anything apart but after some reading seems like its the front strut bearing??
Does anyone have a picture of this part or how to tell if its bad?
Any other sugestions??? Thanx.
Originally Posted by EvilRoadsVictim
control arm? when you accelerate, the joint will move forward/backward a little making the popping, and when you flex the strut, it will make a noise when going up and down.
Originally Posted by theMax
This is not normal correct?
had that go bad on my 4th gen and it used to creak whenever i hit the gas, since there was enough force to make it move ever so slightly making it pop.
so it's defenitely worth a check.
foodmanry
09-24-2015 12:02 PM
ballerchris510
09-11-2015 05:29 PM
Violator
09-09-2015 10:14 AM
