code pulled "1320," what does it mean ? autozone didn't know . . .
THE ses light has been on for about a month now, and I have NOT noticed any performance problems. I got the code pulled at the local AUTOZONE and the it came up as 1320 (an ignition/ emission control problem), however, the clerk at AUTOZONE did not know what it was for.
just before you spent 300 dollars on the coil......let's check what FSM says about this code:
P1320 ignition signal.
OBD logic : malfuction is detected when the ignition signal ib te primarty circuit is not sent to ECM during engine cranking or running.
possible cause
1.harness or connectors to the coil
2.power transistor unit built into ignition coil ???
3.condeser
4.crankshaft position sensor
5.crankshaft position sensor circuit.
Originally Posted by FameMax
Dont goto AutoZone anymore, just ask questions here
I got the same answer at AutoZone today. Still after reading all of this, don't know what to do. I am a 50 year old female who needs answers to be in English not mechanic language. Can't replace car so I guess I'll keep looking for answers.
If you need to replace coils, you will have to remove the intake manifold. You may as well replace the plugs as well. Cassandrab, if you are not mechanically inclined I would recommend finding a local .org member or garage to replace coils. First step is to clear the codes and see if it comes back. If it does then you need to do something.
But completely agree with clearing the codes and making sure it comes back first. A bad coil should be very noticable as the engine will idle rough and you'll notice a loss of power.
If the code comes back, I would try to get to each of the coil harnesses and wiggle them and make sure they are plugged in all the way. It would be a shame to spend $400 on coils (and a load on labor if you can't do it yourself) and it doesn't solve the problem.
If you want to read more, there is a ton of info on coils if you search the org.
Well that depends on whether you have a VQ30 or VQ35. You don't have to remove the intake manifold on a VQ30 to change the rear coils or plugs.
I put in a new MAF, Starter, Ignition Coils, Spark Plugs, Cleaned the Throttle Body, cleaned the Neutral Shift, and added SeaFoam to the brake boost vacuum line: the car still has the 1320 code, plus runs rough in drive. I recently took it in and had the power steering hose replaced, main oil seal replaced, and gaskets replaced.
I noticed what looks like a large electrical t-joint under the air box that has two ends connected to each other and the other end is empty. Should there be connectors to that third end? It's just hanging under the air box.
Any help with the code and/or the large electrical t-joint would be greatly appreciated!
I would wait and reset ecm if cars not running bad, wait till code comes up again and check for A second code indicating coil which is bad.
I have a similar problem but have done the following:
Costs associated with 1320 code
We already cleaned the TB and used SeaFoam...but still have the 1320 code. We're pretty stuck...
It started last winter. I thought it was the cold weather. When at a stop light, it was like we were in a low-rider bouncing back and forth. It's not as bad now, but it still has a rough idle. We've cleared the code several times and it keeps coming back...
Would you know anything about the large electrical t-joint under the air box?
I would put old ones back on and reset ecm...then wait for cel to come back on and check codes again, usally their would be another code indicating cylinder misfire and # plus 1320 code...then replace only coil from that cylinder....1,3,5 cylinder is in back of engine left to right and 2,4,6 is infront from left to right....it could be one only thats bad,so buy A new one at autozone for 80 bucks and keep reciept just incase.
Coils are readily available for much cheaper, one search brought me this:
http://www.nextag.com/nissan-maxima-...l/compare-html
On the TSB # NTSB01-079 from the local dealer, the reference number for the right side coil is: 22448-2Y000 or 22448-2Y001 for the left side the reference number is: 22448-2Y005 or 22448-2Y006
I don't know if that make a difference or not but I'm in Canada.
As for buying 3rd party coils, save your money. They will either be bad immediately or go bad soon. Save yourself the hassle and money and stick with OEM coils with the grey dot. $149 for 6 coils? Good luck with those. 3 month warranty. I bought 6 coils on ebay and all went bad within 2 years, one at a time.
000/005 are the 2000 part numbers and 001/006 are the 2001 numbers. The parts are interchangeable and are probably exactly the same part.
The fifth item in the link I provided, are grey dot and sold for 67.77$ each (hitachi) which is better than the 107$ some dealer asked.
I bought the grey dot coils from Meximax, but people complains about how expensive are the coils so I did a search to help them. Now it's up to them to decide but remember, some people are in bad financial situation and need to find alternative.
03-12-2020 12:06 AM
The Wizard
24
10-01-2015 08:47 PM
