2002 Maxima Concerns/Questions
Old Feb 15, 2004 | 07:13 PM
chaoticz's Avatar
1) I have a 2002 Maxima SE. A few weeks ago I slammed on my brakes and the area around the front wheels vibrated violently. I only had this occur about 2 or 3 times and only when braking very hard.
2) When I make sharp turns and brake at the same time (at higher speeds), I feel like the brake pedal is rubbing up against something.
3) When hitting small bumps on the road my steering wheel seems to jerk to one side, the jerking isnt that violent that I feel I will lose control of the vehicle, but I dont know if this is "normal".
Thanks in advance.
Old Feb 15, 2004 | 08:26 PM
zipper's Avatar
No 1. I've heard this so many times. This is ABS, it is supposed to do that. ABS quickly breaks/unbreaks the tires to prevent you from sliding on melted rubber.
No 2. ??? Sorry don't know
No 3. Are both tires hitting the bump at the same time, or at different times?
-Zipper
Old Feb 15, 2004 | 09:27 PM
chaoticz's Avatar
-Zipper
I just read some TSB about a brake Judder problem; I was thinking if that could be a possibility also. The TSB only refers to 2000 Maximas, however.
Old Feb 15, 2004 | 09:35 PM
Ferbs02SMMax's Avatar
Brake judder corresponds to all newer Maxima's
NTB00033
http://www.nissan-techinfo.com/nissa...0.asp?mscssid=
3) The suspension is tuned so the driver gets a lot of feedback from the road. The SE suspension is quite harsh, when compared to other import sedan's, so any irregularities in the road, you will feel. One of the drawbacks of the SE I suppose, but you should be fine.
Make sure the tires aren't overinflated, as this may be the cause you are getting as much road defects intruding into the psgr cabin.
Having overinflated (or underinflated) can adversely affect ride quality, fuel economy, tire wear.
Fernando.
Old Feb 15, 2004 | 09:43 PM
6spmax's Avatar
I posted about this last week. I have the same issues with my '03. Dealer pretends nothing is wrong. The TSB won't help you because it's not covered under 3/36000-only on the 2000 Max.
Old Feb 15, 2004 | 09:45 PM
zipper's Avatar
I hadn't thought about the brake judder, hmm, I have a little on mine I guess but it's not as bad as he made it sound. Sorry if I was incorrect, I've just seen alot of ppl freak out over ABS.
Old Feb 15, 2004 | 10:05 PM
XxJ822xX's Avatar
Thanks in advance.
1- most likely your ABS
2-dont know....sorry
3-Happens when you hit a bump sometimes going a little fast
Nintensity
Aug 13, 2015 05:41 PM
fastcarny
Aug 12, 2015 03:50 PM
papo99
Aug 9, 2015 07:24 AM
yat70458
Aug 3, 2015 01:16 PM
