Quick PCV valve replacement question
Old Feb 21, 2004 | 09:47 AM
CCx's Avatar
CCx
Replaced PCV valve this afternoon, when putting the hose back on, i could not get the clamp to go all the way back to its original position. I had a hard time using pliers to get it loosened, and getting it back on was a pain in the butt.
I figure when I take out my airbox to install my intake, I can get a better angle on it, but for now, does it matter that the clamp is about an inch back from where it should be? It's probably going to be this way for at least a few weeks. If it's a critical issue, I'll gladly acquire a pair of those real long-nose pliers and attempt to tighten it over the valve. This is the bottom part of the hose that goes over the PCV valve, the top part was no problem.
Thanks in advance.
Old Feb 21, 2004 | 04:21 PM
bsetiawan's Avatar
I guess it's not fatal if that hose comes loose. The most you'll get is SES light and it might create a little mess under your hood since that gas is dirty.
Old Feb 21, 2004 | 04:45 PM
Zero Deuce SE's Avatar
If that hose were to come loose, it would draw unfiltered air into the intake. In a dusty environment, it would be fatal for the engine. It probably won't come loose if it has a ridge inside the hose that matches up with the PCV valve. I would put it back on just for peace of mind if nothing else.
Old Feb 21, 2004 | 07:34 PM
CCx's Avatar
CCx
Ok, I drove it earlier, but I'll go ahead and get a pair of the long-nose pliers and put the clips back on over the actual valve rather than an inch back on the hose where it rests currently.
Thank you for the help, guys, I appreciate it!
Old Feb 22, 2004 | 04:20 AM
You're welcome, anytime.
lowpost99
22
Sep 2, 2015 04:38 PM
lux97Max
19
Aug 27, 2015 07:48 PM
maxinout93
Aug 20, 2015 02:17 AM
doobadoo
Aug 15, 2015 06:43 PM
classymax420
Aug 6, 2015 06:35 PM
