My impressions of the Hotshot Headers
#122
Originally Posted by DUKEE
gotcha. yah that one. what about getting a stock gasket for between the cat and y pipe. are those okay?
#124
okay cool. so ill go and get a new 2.5 gasket for the y-pipe to cat. what about the top portion of the headers. what gaskets should i get for those? thanks
#126
when installing the headers did you guys end up using the o2 simulator? or did you simply extend the 02 sensor to fit? if you did, i read it was in the way of the ac comppressor line. am i correct?
#127
![](https://maxima.org/forums/images/smilies/support.gif)
The sensor thats in the way of the compressor is a primary that cannot be simulated. I moved that sensor to the front manifold collector (do not have to extended the wire on an 00-01), the rear stays in place, then I simulated the two secondary o2 sensors.
So there are four sensors in all, two primary and two secondary.
You can only simulate the secondary sensors.
Edit: you are a Cali spec car?
#131
Originally Posted by Puppetmaster
I'm pretty sure all 2001s are CALI spec.
I thought some EARLY ones are fed spec, best way to tell is to look at the front of your motor and look at how many o2 sensor harnesses you have...
If you have four, you are a Cali spec.
I thought that they did not start making them all Cali till 02+.
#132
http://maxima.theowensfamily.com/tsb/NTB02-051a.pdf
Regardless, people need to learn how to pop the hood and do some looking around on their own before posting questions.
Dasmith
09-23-2015 08:28 PM
